Torque Pro on the Kona - overview and setup for interested owners
Discussion in 'Hyundai Kona Electric' started by KiwiME, Sep 26, 2019.
  1. FloridaSun
    FloridaSun Well-Known Member
    how to set up displays in torque pro
  2. Thanks for that:)
    FloridaSun likes this.
  3. FloridaSun likes this.
  4. JD Solar and EV
    JD Solar and EV New Member
    To help make a tricky process easier I made this Torque Pro App install video for the steps for my Kona Electric.
  5. mikeselectricstuff
    I just did this a couple of days ago - what I couldn't figure out was how to get all the cell voltages displayed without having to add each one individually to the dashboard , and then change the number of decimal places on each one. I even looked at manually editing the layout file but the format wasn't obvious enough.
    I ended up not bothering with individual cells, and just used the min/max cell number/voltage, and deviation values.
    ALso, is there a quick way to delete all the ICE stuff on the dashboard and remove the unused panes ?
    Considering how popular this app is, I'm surprised at how painful the process of setting up a new car is.
  6. ericy
    ericy Well-Known Member
    That's why I like SoulEVSpy instead. It is designed for EVs without a lot of fiddling around with configuration, and it works with all of the Korean EVs.
  7. Certainly SoulEVSpy is convenient for quickly evaluating cell balance with the colour-coding.
    I haven't yet bought the non-Lite version to try out the data logging and .csv export.
  8. MikeDD
    MikeDD New Member
    Here's a Excel spreadsheet that can reformat an existing Torque dashboard.
    I've only used it to adapt a dashboard to my phone screen size and preferred layout. However it can also edit decimal places. Eg manually edit column Q on sheet '4 build new'
    http://excelobscura.blogspot.com/2020/02/torque-dashboard-formatter.html
  9. hieronymous
    hieronymous Active Member
    No group pid commands sadly - one action at a time. Min/max voltage points to any potential problem anyway.
    The ICE stuff always arrives with a new profile, one at a time deletion..
    General Prefs allows a choice of number of panes, 1, 3, 5 etc. So start with 1, add more if needed, minimises deletions (more bring default ICE stuff though)...
  10. herode10
    herode10 Member
    Max Power & Max Regen are still available but you need to update the PID and the bytes in the Torque Pro. Thoses values haves always been available on 2 different PIDs: 220101 and 220105. The values on 220101 have been replaced by something else with the BMS software update but they are stiil available on 220105. For the Max Power, change to PID 220105 and replace bytes f & g for q & r. For Max Regen, change to PID 220105 and replace bytes h & i for s & t
    robxb likes this.
  11. robxb
    robxb Active Member
    Wow great tip, thanks so much! :D
  12.
  13. I have a EV kona ultimate 2020 I replaced Veepeak VP11 and all my temperature read i C not F and I do not now how to change. Pls I live i New York Help 'Thank You I appreciate ,Janusz Grabon
    hieronymous likes this.
  14. FloridaSun
  15. There was a question on FB recently about the definition of a charge/discharge cycle. As most of us know it's defined as a charge and discharge cycle of an energy quantity equal to the rated capacity. Wiki defines it as "... the process of complete charging and discharging". Added to that, a comment from Apple Inc. says: "... a charge cycle means using all the battery's capacity, but not necessarily by discharging it from 100% to 0%...".
    So, completing a "cycle" doesn't have to happen from zero to 100% and 100% to zero in one shot. An accumulation of multiple charging and discharging events equalling the rated capacity is still a cycle, as there is nothing implicit as to over what range of SoC those events occur.
    When we look at an Li-ion 16850 cell life graph (see below), the lines represent cycles between a number of fixed SoC values aside from the default of zero and 100%, eg. 25 to 75%. Those are plotted against "DST cycles", where they mean 100% cycles. So, the X-values on the 25 to 75 line are the cycle numbers normalised to a defined 100% cycle, i.e. half of that. If the cell life data for 25 to 75 indicates 3,000 "cycles" are available from a particular cell sample at a particular deterioration level (say 90%) then that actually means 6,000 cycles can be acquired when only going using it between 25 and 75%.
    We already generally understand as owners that avoiding SoC extremes "can" increase the useful life of the traction battery. "Can" is just being scientifically-conservative or non-committal, I would suggest that the data shows that it most certainly will.
    Obviously when you are driving the Kona it's continually discharging and (in much smaller amounts) charging (regen or 'recuperation'). That activity is depreciating the battery life and that is one of the reasons why the BMS records the four data values with titles that start with "Cumulative ...".
    There are two primary values measured from the precision current shunt inside the traction battery, one for "cumulative charge current" (CCC) and one for "cumulative discharge current" (CDC). When matched up with the pack voltage at the time of measurement the related values "cumulative energy charge" (CEC) and "cumulative energy discharge" (CED) can be calculated. These numbers will be continually updated in the BMS's memory whenever the car is fully awake, just like odometers. Torque Pro just reads them straight off the BMS and puts them in readable, decimal kWh form.
    (In an earlier post in this thread I described a theoretical way that SoC can be calculated from the CEC and CED at any time, provided that the SoC at factory initialisation is known.)
    While answering the FB question I realised that you can calculate how many 100% cycles your battery has endured simply by dividing the average of CEC and CED by 64 (kWh). Since these values become much the same over many cycles, you could also make an estimate from either one instead.
    Unfortunately both BMS updates zeroed-out all these valuable numbers, but if you happen to have the values recorded before the update(s) you can calculate the cycles from when the car was new by adding them up.
    In my case I have data to show that I've used 44 cycles before and 1 cycle subsequent to the updates (in my case all updates were applied 2 weeks ago), so I've used 45 cycles off the battery life at 16,600 km. That number BTW, is related to the efficiency rating so many of us in mild climates would have similar numbers. Those in very cold climates could be as much as double.
    If I had charged and driven the car from 100% to zero over those kms I could make a fair assumption that my battery would only be useful for the shortest typical life of a Li-ion battery, perhaps only 400 cycles. If I had confined my usage to say 30 to 70% then I could also fairly assume that I might be able to rely on a much longer life, perhaps 3,000 100% cycles per the graph below.
    I'll leave it up to the reader to grab a calculator and figure out how far I could drive in those two scenarios. As a clue if needed, it's (400/45) x 16,600 km and (3,000/45) x 16,600 km. Now, obviously there are other major contributors to battery deterioration to consider, mostly time and temperature, but also frequency of rapid charging to some degree.
    Still, these numbers put our SoC considerations in perspective.
    This annotated graphic for a single 16850 cell was created from the original copied from batteryuniversity.com
    electriceddy and apu like this.
  16. Thanks for some this metod is not working for my android 10 phone . What is my next option ? Janusz G
  17. FloridaSun
    Weird. I was on Android 10.. just 2 days ago, I upgraded to Android 11 on my Samsung Note 20 Ultra..
  18. I have also been keeping track of CEC and CED numbers before and after updates and for the sake of another data point with several months in Canadian cold and it looks like I'm at 64 charge cycles with approximately 23500 km on the clock. This would represent a 2% degradation based on a 3000 charge life cycle.
    KiwiME likes this.
  19. Do I have to do this in a car or not
    Do I have to do this changes in a running or not ?
  20. FloridaSun
    it worked for me on Android 10 or 11..
    There is nothing you can do on the car.. It has to be done at the level..
