Mods for your Clarity
Discussion in 'Clarity' started by alyssai, Apr 28, 2018.
  1. toomie
    toomie Member
    JJim likes this.
  2. insightman
    JJim likes this.
  3. V8Power
    V8Power Active Member
    JJim likes this.
  4. JJim
    JJim Active Member
    Glad you find it useful. If you have problem with installation, I will show my tip.
  5. Johnhaydev
    Johnhaydev Active Member
    If you look at the photos, the bag has an adjustable strap with a buckle that would be used to hang it off the back of the seat. Instead, it’s long enough to loop around the floating center console.
    leehinde likes this.
  6. V8Power
    Please do and save us the struggle! I was wondering how to fasten it...thanks again!
  7. JJim
    JJim Active Member
    Just use a long think stick to hold the clip into position.
    Ordered another one yesterday. I hope it arrived as soon as you get your, so I will show some pictures.
  8. insightman
    A think stick! That must be a stick that knows exactly where to position the clip behind the hole, right?
    I think you meant "thin," but with one letter changed, you might have meant "thick," too. A thick stick might hold the clip against the hole better than a thin stick, but it probably takes a thin stick to get the clip where it needs to be.
    JJim likes this.
  9. V8Power
    Thanks!
  10. JJim
    JJim Active Member
    I meant thin but what ever as long as you can hold the clip and put it through the square opening to reach the farther hole. Since I am not good at words, I took 1 screw off and take some pics for reference 20180911_150410.jpg 20180911_150419.jpg 20180911_150729.jpg 20180911_150611.jpg
    qtpie, toomie, V8Power and 1 other person like this.
  11. V8Power
    West1 and JJim like this.
  12. Bravo1231
    Bravo1231 New Member
    Hi Jim,
    I’m looking to put the cargo net in but I think I like your install better then Honda’s. Which ancher points did you use for the bottom?
  13. JJim
    JJim Active Member
    Since I don't want to drill my car, I hooked the bottom of the net into the corner of the black plastic piece, it firms and holds the net pretty good. 20180914_093650-1.jpg
  14. Gh0stb0y
    Gh0stb0y New Member
    Hi Jim, I'm trying to install the cargo net the way you have but I realized after I took the clips out that it wouldn't really "lock" the net hook in since I can't reach the back of the hole. Could you tell me how you did it? Thanks.
  15. JJim
    JJim Active Member
    For the cargo net, I replaced the original clip with the hook ring which bought on Ebay and used the small plastic wall anchor to install it in to the hole
    https://rover.ebay.com/rover/0/0/0?mpre=https%3A%2F%2Fwww.ebay.com%2Fulk%2Fitm%2F322346645106
  16. stanigu
    stanigu Member
    I used Vice Grip to hold the nut in place (in installing OEM cargo hook, which otherwise would require some specialized tool)
  17. Gh0stb0y
    Gh0stb0y New Member
    That's awesome. Thanks! I didn't want to drill the hole nor did I feel like spending $30+ to get the rivet nut tool just for this.
    It's crazy to me that these manufactures have these accessories that requires us drilling holes in their instructions.
    West1 likes this.
  18. V8Power
    I followed your tip and used a small vice grip and it worked great! I used the clips supplied as bolts and only needed to add a washer for the larger hole. The bags perfectly reach the trunk floor. Thanks everyone!
    Hobbesgsr and JJim like this.
  19. BLAZETIGER
    BLAZETIGER New Member
    Thanks for the tips on installing the cargo bag holder. It was a pain to install, but everyone's tips plus the pictures helped.
    Now on to the cargo net...
  20. This was great. Also installed the hooks using this method--works perfectly.
