Clarity PHEV wiper replacements sizes?
Discussion in 'Clarity' started by DC1, Dec 5, 2018.
  1. PHEV Newbie
    PHEV Newbie Well-Known Member
    I'm still using my original set of wipers (as good as new), original air filter (clean as a whistle with few ICE miles) and original cabin filter (still clean) but I'm on my 3rd air conditioning condenser and probably will need a 4th soon.
  3. coutinpe
    coutinpe Active Member
    My wiper blades got deteriorated somehow after a windshield replacement. I spent $35 on a pair of Rain-X 26" wipers, but I wasn't happy with the results. They were protracting so much it affected visibility, and the function wasn't the best, still leaving tracks of water after 4 or 5 sweeps. So I decided to buy "refills" for the original wipers and got this at Amazon for 7 bucks:
    https://www.amazon.com/dp/B0BTVGBTMG?psc=1&ref=ppx_yo2ov_dt_b_product_details
    They work as a charm, quiet and efficiently, and I made the exchange in less than 10 minutes...
  4. I took some measurements of the OEM wipers. From the mounting/pivot point on the arm to what I will describe as the inner end of the blade assembly, near the center of the windshield while in the stored position, the length is 12.75”. The length from the mounting/pivot point to the outer end of the blade assembly, near the A pillar, is 13.25”. It is the same for both assemblies and they are side specific, hence the requirement for 2 part numbers.
    If the assemblies were to be installed on the incorrect sides, the inner end, which would become the upper end while in use, would extend .5” beyond correctly installed blades. Aftermarket assemblies that have a centered mounting/pivot point would extend .25” beyond the OEM assemblies.
  5. Fe2_O3
    Fe2_O3 New Member
    Thanks for the rec! How long have these lasted you? More than a year?
  6. coutinpe
    Almost eight months. Not that I use them very much since I live in the desert, but the few times I activated the wipers they do just fine, so far.
