Clarity PHEV wiper replacements sizes?
Discussion in 'Clarity' started by DC1, Dec 5, 2018.
  1. LegoZ
    LegoZ Active Member
    Just a heads up on new frames and arms. I tried to do Bosch Envisions and they are not setup for our cars as they say it’s the same blade on each side the passenger side spoiler is backwards.
  2. YesKay
    YesKay New Member
    If your car is less than 1 year old, your dealer will replace wiper blades if you complain
    Changing just the inserts is the cheapest option. You can get OEM wiper inserts at this link: https://www.hondapartsnow.com/genuine/honda~rubber~blade~650mm~76622-tdk-j01.html?Make=Honda&Model=Clarity+Plug-In+Hybrid+&Year=2018&Submodel=&Filter=(bt=4%2c3838;et=2%2c4)
    You can change the inserts (or the entire wiper assembly, if you so wish) using instructions at this link: http://techinfo.honda.com/rjanisis/pubs/QS/AH/ATRW1818GW/enu/pages/GUID-F98F85F0-40C0-4119-87AD-6CDCAB86A865.html
  3. jdonalds
  4. jdonalds
    They wanted over $11 for shipping...
  5. jdonalds
    Since the blades are both 26" I'm thinking of simply swapping them to see if the noise goes away. I've already applied RainX.
  6. LegoZ
    LegoZ Active Member
    They are not identical, which might be the problem, maybe they got flipped around backward. I don’t know how to explain this at this moment though...
  7. jdonalds
    Oh. I did a rough measurement and thought they were the same length. They can't be off by much.
    I don't mean to swap the whole assembly, just the insert.
  8. jdonalds
    Okay I just swapped the soft insert. The whole assembly isn't intended to be swapped. There is a raised area along the edge which I would guess is a spoiler to hold the blade down onto the windshield at higher car speeds. If they were swapped that spoiler would be on the wrong edge. I don't know if this will fix the noise problem. Since I already applied RainX I may never know. I've also ordered new inserts.
    They are indeed equal lengths.
    I think the soft part that rests against the windshield can take a "set" just sitting there in the summer heat. Last year we had 178 consecutive days with no measurable rain.
    We're supposed to get rain at the end of the week.
    LegoZ likes this.
  9. LegoZ
    LegoZ Active Member
    Swapping the blade insert will work, it was the whole assembly I was trying to warn about for exactly the reason you described. Thank you jdonalds for having the words when I didn’t.
  10. Ray B
    Ray B Active Member
    Good advice. I found a helpful video of the process here.
    I will try it because the OEM wiper experience has been one of the worst aspects of the car in my view.
    Dan Albrich likes this.
  11. petteyg359
    petteyg359 Well-Known Member
    FWIW, on mine the OEM passenger assembly was already "reversed". I very much doubt any company is going to be selling a special "backwards" assembly for the passenger side. That's just the way it is, just like with the wheel covers being backwards on one side.
  12. su_A_ve
    su_A_ve Active Member
    Finally I got around on replacing the second one. HUGE difference! These don't skip or anything. Wonder if the ones being installed in Japan are of different quality since it looks like most owners are having the same issue.
    Depending on the cost, for the next set I may get the OEM ones, but hoping someone else gets them and say they are good first.
  13. Sandroad
    Sandroad Well-Known Member
    For the cost of shipping, I'd be happy to UPS my new PIAA wipers to anyone interested in trying them. Maybe you'll have a better experience than me?
  14. AlanSqB
    AlanSqB Active Member
    Installed two 27” Rain-X latitude blades two weeks ago. You have to remove the outer part of the connector for it to fit but after that they plug right in.
  15. Sandroad
    Those working well?
  16. AlanSqB
    Yes. Other than being a little ugly, they work really well and very quietly.
  17. vicw
    vicw Active Member
    I didn't want to wait for the long estimated Ebay delivery time for replacement wiper refills from China, so I picked up a pair at my local Honda Dealer. They charged me $7.46 ea, for Part No. 76622-TDK-J01, and the replacement was really easy.
    The only minor problem I encountered was trying to get the blades into the maintenance position, using the procedure in the User Manual on Page 496. I tried several times, but I just couldn't get them to stop in that position. Has that procedure worked for others?
    craze1cars likes this.
  18. craze1cars
    craze1cars Well-Known Member
    This is how I get my wipers, like @vicw does, $15 a pair of refills from Honda dealer, 60 second install each. As for the “maintenance position” question. I just pick them up and they stick straight up away from the glass and work on them like that. Same for all cars. Frequently done in winter regions before ice storms to prevent wipers from freezing to windshields... you’ll often see hundreds of cars with wipers pointing to the sky at an office building near you before a predicted ice storm. I Have no idea what the manual says...but if “maintenance position” is more complicated than that, I say ignore the manual and just lift them up.
  19. megreyhair
    megreyhair Active Member
    My original blades skips and have streaks. I flipped the insert around and that took care of the streaks but it was still skipping. Rain-X helped and the skipping was gone. I tried Rain-X blades like AlanSqB suggested but they were horrible. Skipped and jumped like crazy and I took them off. Waiting for next rain storm to try out the eBay's $2 silicone refill.
  20. ClarityBill
    ClarityBill Active Member
    I used my left hand to lift wiper control to 'mist' position. Turn on the car by pressing the power button: Wipers go up and down once. While still holding the wiper control, I pushed the power button to turn the car off, and the wipers move to maintenance position. Seemed pretty easy.
