Weird charging behaviour?
Discussion in 'Hyundai Kona Electric' started by Wildeyed, Jun 15, 2019.
Tags:
  1. I charged 3 days ago to 100% and left the car plugged in. I haven't used it at all. But last night the charge port was illuminated. The Blue link reported that it was full and not charging. What's up with that?
  2. Maybe it lost a little bit of charge, like a percent, since you didn't use it and filled it up again?
    XtsKonaTrooper likes this.
  3. Maybe. I thought of that. The only hiccup is the Blue link saying it wasn't charging. But, let's face it, Blue link is not terribly reliable so it might be misreporting.
  4. XtsKonaTrooper
    XtsKonaTrooper Active Member
    After it reported it was fully charged, and sent out the alert or email, it dropped a percentage and youyou j happened to walk by and looked at the indicator.
    Or
    It was ET calling home and it then needed a little charge.
  5. What color was the illumination? Also maybe it was charging just for a few minutes and when you checked on the app it was done?
  6. I'll leave Aliens aside for the moment... The light was green, the "battery" indicator was flashing and showed full. The light was on a full 3 hours after scheduled charging starts. (A long time for a simple top-up) According to Bluelink the range had dropped only 1km from 3 days earlier.
  7. If it had been only a half hour after scheduled start and had then shut off I wouldn't have thought a thing of it. But 3 hours is enough time for a 30% top off.
  8. Hmmm, I can't come up with any reasonable explanation, aliens are unlikely. So I'd go with your car was bored ...
    Maybe it wanted some attention. Looks like that worked ...
  9. Just curious, what type of EVSE do you use?
  10. Sun Country 40amp
