I have seen several postings in the past of detailed pictures of the Battery Cell Voltages and variations for every cell. (bearing in mind this new Recall Campaign 960). Are you guys getting those figures using the TORQUE PRO App (paid version) with the accompanying OBDII Dongle? Which setting gets you those values? I have the Dongle but have yet to purchase the PRO version if THAT's not what I need. Thanks so much.
Hi, Yes, most people use Torque Pro although there are other options like CarScanner which are simpler to set up. For Torque you need setting up external PIDs for Kona that you can find on GitHub. For the 96 individual cells you need to download and import a Dashboard file that someone kindly shared on this forum. Other option instead of those 96 sensors is using just two, one with the Max Voltage and one with the Minimum. There's another one with the difference between those two, but it always shows 0 for me. Good luck
I get the figures using Torque Pro (paid version) with extra PID's from JejuSoul on Github installed into the app https://github.com/JejuSoul/ It takes an age to set up the 98 PID's for cell voltage, and you also have to set 2 decimal places for each of the cell PID's I have created a dasboard file which makes setting up Torque Pro easier:- You can also use Soul EV Spy - It's easier to use, but much more expensive:-
It's a lot of work to define all 98 cell groups to the screen.. There is no way to do all at the same time.. Torque Pro is cheap as you have to do a lot of work manually to make it work.. SoulSpy is basically plug and play. I grouped 96 cells on one page, overlapping each other... Cell 97 and 98 are on another page..
Thanks guys !! I think the SOUL EV Spy is the way to go for me ... a lost less work, and from looking at the LITE version, makes a lot more sense.
If I would have known about Soulspy, I would have gotten it but at the time when I got Torque Pro, it was the only one I was aware of..
There are PIDs for min and max cell voltages, and deviation, to avoid the need to show all the cells.
I have both - I had gotten TorquePro long before I had the Kona. One thing I like about SoulEVSpy is that I can reload a previous session that is stored on the phone, and use that to see what things were like in the past.
If you insist on looking at every cell block individually, you can probably accelerate the configuration process a little by scripting up a template for a .CSV file, editing in all the appropriate labels/offsets and maybe even gauge positions?? in a real editor with a real keyboard, and then crossload that into Torque. I've also pointed out the two figures that are much easier to deal with, lowest cell voltage and highest cell voltage. You can even graph just those two figures together while putting the pack through various forms of abuse, to try and ferret out potential (heh) issues under high load. Data comes back a lot faster because it's only two OBD2 queries instead of 98, assuming Torque is as stupid about multiple queries/responses under the same PID as the other "pro level" packages. Maybe SoulSpy etc are better about aggregation? The queries, btw, are CAN ID 7E4, mode 22, pid 0101. Returned byte X / 50 gives you max cell voltage, Z / 50 gives you minimum. Resolution is 0.02 volt. Reorder the fields however is appropriate for your app. Figures for *which* cells are the specific high/low ones can also be had via the Y and AA parameters, and in theory should bounce around all over in a well-balanced pack, but on mine, never more than 0.02V different that I've ever observed, those high/low N tend to settle on a small handful of values like 1 and 84. That probably has more to do with the internal scan order that the BMS does, not actual cell variance so far. I'd be interested in what other folks see as their own min/max N, too. _H*
For a charge session, plus “sitting” afterwards, my Kona’s typical min/max pair is 28/46, min more stable than max. The pack is boringly consistent to spec at any charge level, just the regularly occasional 0.02 variation...
