Does anyone know the starting brake pad mm on a 2018 Clarity? I just got my car serviced at 7600 miles and my fronts are at 9mm and back are at 8mm. I want to know what they started at so I can estimate when they will need to be replaced and decide if I need to be better about my braking habits. Thanks!
First, measure yourself! Take what the dealer reports with your scam alert set on high. I find it hard to believe you're wearing the rear pads 20% in only 7600 miles (assuming what @petteyg359 noted as new is correct).
