Not even 600 miles...
Discussion in 'Clarity' started by su_A_ve, Aug 10, 2018.
  1. su_A_ve
    su_A_ve Active Member
    $200 something for the tire, plus at least $100 for mounting and balancing...
  2. weave
    weave Active Member
    Oh no. :(
    Did you use the tire repair kit at all? Or just pull over and wait for a tow?
  3. su_A_ve
    It’s slit on the sidewalk. No way the repair kit would fix this.. still waiting for a tow. Supposedly a flat bed is being sent.
  4. su_A_ve
    So... I stopped right after hitting the curb. So far the TPMS indicator has not detected the flat.
    It would only do it if driving? I know it’s “indirect”
  5. weave
    weave Active Member
    Ugh.... sorry you had to be the first here....
    From what I read elsewhere here, the TMPS doesn't include a detector inside the tire (for better or worse) but somehow detects it based on a slightly different speed between each side, or something weird like that.
    Based on that, then yeah, I think it requires it to roll for a bit.
  6. JJim
    JJim Active Member
    Still lucky enough to not damage the alloy wheel :-D
    Domenick, leehinde and weave like this.
  7. TPMS on the Honda uses the ABS wheel speed sensor to calculate when a tire is low.
    That price for the tire and installation is very high, but in an emergency you are kind of stuck.
  8. insightman
    insightman Well-Known Member
    On the positive side, with the Clarity, you never have to worry about the goo from the pump ruining an expensive (and yet often unreliable) tire-pressure sensor inside the tire.
    On another positive side, if you have to get a new tire, it's good to get it when the wear on the other 3 tires is still minimal.
  9. ClarityPHEVer
    ClarityPHEVer Member
    Yup, same thing happened to me, you can search for my flat tire thread. The day after I got my new tire, the TPMS gave an alert. If that happens, check your pressures and if they’re all good, reset the TPMS through the settings in your head unit. Of course I brought my car back in to the tire place only to learn I could have reset it myself! Hope this saves you a return trip if yours alerts afterwards.
  10. su_A_ve
    If I had a spare I could have shopped around for a new tire. Maybe I'll get AAA again so I can have it towed wherever I want to and not the Honda dealer.
    Thinking seriously now to get one, even if I keep it at home... Next set of tires it's either Costco or Sams
    Johnhaydev likes this.
  11. Gearhead
    Gearhead Member
    I upgraded my AAA membership to get up to a 200 mile tow. This way I can get to a reasonable tire shop if necessary. In the meantime I'm as careful as I can be when parking. Coming out of a SUV with 60 series tires it's an adjustment. I had 45's in my '06 Infiniti and it took 2 replacement tires (total damage around $700) for me to get it. After that no more sidewall abuse.
  12. iluvscuba
    iluvscuba Active Member
    Sorry I am confused. Why do you need AAA membership, I thought this car has a 3 year emergency assistance (including tow) service?
  13. bpratt
    bpratt Active Member
    P1030716.JPG So here is a picture of my spare tire.
  14. Odobo
    Odobo Active Member
    Your insurance don't cover emergency towing?
  15. insightman
    By the time you found a towing company with an available flatbed truck (required for the Clarity), and waited for that truck to get to you, a spare tire would have enabled you to already drive yourself to the tire store (with no worries about careless towing company damage to your aluminum-clad Clarity). And if the tire store to which your Clarity was towed didn't have the exact tire you need...
  16. ClarityPHEVer
    The Honda emergency assistance will happily tow you if you have a flat- but only to the nearest Honda service location. When I got my flat, I originally called Honda assistance, and they told me that. I ended up cancelling and calling AAA because Honda was 20 miles away and the tire place was 2 miles. (Plus I got my flat outside my kids swimming lesson and staying local allowed me to get it taken care of while they had their lesson vs having to get a ride for me and the kids to Honda since two kids + me can't ride along in the tow truck.)
    iluvscuba likes this.
  17. su_A_ve
    Got the tire replaced. Somehow my HV range dropped 5 miles so wonder if/how they managed to turn ICE on. On the other hand, I asked them to charge it and they did.
  18. Nathan66669
    Nathan66669 New Member
    I fully read the owners manual over the past couple days and it had little to no info on spare tire. I never even thought to inquire on this....
    So the car doesn't have a spare at all? Is that just a little electric compressor and they expect your flat to be just a small leak and keep it inflated till you can get a plug installed? That would be pretty important info for me, certainly even more so if my wife is out driving.
  19. leehinde
    leehinde Active Member Subscriber
    Correct.No spare. If it's a serious flat you need a tow (by a truck with a platform).
  20. Odobo
    Odobo Active Member
    The insurance question was more for getting the AAA membership for towing....
