Model S Plaid Delivery Event
Discussion in 'Model S' started by bwilson4web, Jun 11, 2021.
  1. bwilson4web
    Source:
    Relatively short, 29:02, it is concentrated engineering excellence. This was the livestream event only InsideEV was wise enough to share without 'talking heads.' We're looking at hypercar performance for luxury car price, $130k.
    Over time, I hope to add details to this thread about the significance of this video. There is so much to cover.
  3. bwilson4web
    Index:
    • 00:00-04:16 - Fluff before Elon gets microphone
    • 04:16-06:25 - Why and the "2 second barrier"
    • 06:25-06:52 - 'Physics is the law and everything else is a recommendation."
    • 06:52-07:33 - 'Supercharger speed of 187 miles in 15 minutes"
    • 07:33-08:43 - Specs
    • 08:43-11:34 - Carbon over wrapped motor which supports 20,000 rpm over 0-200 mph range
    • 11:34-12:20 - Coefficient of drag 0.208, including wheels in motion
    • 12:20-12:53 - Highly efficient heat pump and improved cooling, 'does not get winded'
    • 12:53-13:50 - 25,000 SuperChargers, opened 30 this past week, power going from 250 to 350 kW
    • 13:50-14:34 - Expecting lowest probability of injury from NHTSA tests
    • 14:30-15:03 - Interior and exterior redesign
    • 15:03-17:42 - Minimize the controls so the stalks are gone
    • 17:42-20:06 - Improved backset and HVAC controls are screen controlled by front and rear
    • 20:06-25:02 - Displays, sound quieter, UI, way-points, and game processor, PS-5
    • 25:02-25:41 - Power remains flat to 200 mph which solves the backEMF problem limiting electric motors
    • 25:41-26:37 - Deliver starts now and ramps to 1,000 per week in Q3 2021
    • 26:37-29:02 - Video wraps up
  4. bwilson4web
    Of all the presentation, the most impressive is the flat power curve. When a motor spins faster, it begins to work a little like a generator. But the voltage is reversed from the applied field. This limits the power out of the motor as it goes faster which is when aerodynamic drag, the square of velocity force, cube of the velocity power, is most needed.
    Historically, this backEMF has been handled by 'field weaking' (Toyota) or 'switch reluctance' (Tesla) but these only delay the backEMF effect. Tesla has cracked the code and these motors are revolutionary. No one has anything like this.
  5. bwilson4web
    The carbon wrapped motor allows 20,000 rpm by keeping the laminations from stretching out and even 'hand grenading'. The carbon wrap means the rotor dimensions don't have a larger, less efficient gap at low rpms. So the power comes on even faster than previous motors. Best of all, these close, rotor-to-stator dimensions are maintained across the speed range. So it is relatively more efficient and powerful.
