Leasing in the time of Pandemic
Discussion in 'LEAF' started by IanH, Sep 23, 2020.
  1. IanH
    IanH New Member
    I've only driven my leased 2019 Leaf 500 miles since it’s last service interval. Will I be out of warranty if I miss the next service interval (this month!)? Is there a way of contacting Nissan with this question?
  2. Kenneth Bokor
    Kenneth Bokor Active Member
    Hi, check with the dealer or the head office via a customer support line. You should not be out of warranty for not doing service intervals. They are recommended, not mandatory - unless specifically stated. Warranty is more about distance driven and time. However, if it's determined that a failure/issue was caused by a lack of routine maintenance (ie: ICE vehicle engine seizes due to never changing the oil) then an OEM can refuse warranty coverage for the fix.
    Hope this helps.
  3. IanH
    IanH New Member
    Thanks Kenneth.
