Specs for my 2016 https://www.kiamedia.com/us/en/models/soul-ev/2016/specifications Specs for the upcoming 2020 https://www.kiamedia.com/us/en/models/soul-ev/2020/specifications
2020 Specs from above source: ENGINE Electric Motor - - Motor Type AC Synchronous Permanent Magnet Motor Voltage 356 V Horsepower 201 hp (150 kW) @ 3,800-8,000 rpm Torque 291 lb.-ft. (395 Nm) @ 0-3,600 rpm ELECTRICAL SYSTEM High-Voltage Battery Pack - - Battery Type Lithium Ion Polymer Battery (LIPO) Battery Voltage (V) 356 V Battery Capacity (Ah) 180 Ah Battery Energy (kWh) 64 kWh Battery Power (kW) 170 kW Weight 1,008 lbs. Battery Cell Materials Nickel, Cobalt, Manganese (NCM) Cooling System Liquid, via front-mounted radiator and A/C system DRIVETRAIN Transmission Type Gear Reduction Unit Final Gear Ratio (Constant) 8.206:1 DYNAMIC PERFORMANCE Max. Speed (mph) 104 Acceleration performance (sec) - - 0 - 62.1 mph 7.6 49.7 - 74.6 mph 4.8 Brake Performance (ft.) - - 62.1 - 0 mph 137 ft. CHARGING On-board charger (OBC) 7.2 kW Port locations Behind front grille Charging time - - Level 1, AC charge with in Cable Control Box (ICCB) 59 hours (120V) Level 2, AC charge with Electric Vehicle Supply Equipment (EVSE) 9 Hours 35 Min (7.2 kW) DC fast charge with Electric Vehicle Supply Equipment (EVSE) to 80% charge 75 Min (50 kW) / 1 Hour (100 kW) EXTERIOR DIMENSIONS Wheelbase (in.) 102.4 in. Length (in.) 165.2 in. Width (in.) 70.9 in. Height (in.) 63.0 in. Track, front/rear (in.) 61.6 in. / 62.0 in. Overhang, front/rear (in.) 34.1 in. / 28.7 in. Min. Ground Clearance (in.) 6.0 in. Approach Angle (degree) 16.2 Departure Angle (degree) 29.6 INTERIOR DIMENSIONS Seating capacity 5 passenger Head room - - Front (in.) 39.9 in. Rear (in.) 39.5 in. Leg room - - Front (in.) 41.1 in. Rear (in.) 36.0 in. Shoulder room - - Front (in.) 55.5 in. Rear (in.) 54.7 in. Hip room - - Front (in.) 53.5 in. Rear (in.) 52.8 in. Luggage capacity, rear seats upright, with luggage under tray (SAE, cu. ft.) TBD Luggage capacity, rear seats folded, with luggage under tray (SAE, cu. ft.) TBD Luggage capacity, passenger volume (SAE, cu. ft.) TBD CHASSIS/SUSPENSION Front suspension McPherson type suspension Rear suspension Multi-Link Shock Absorber (front/rear) Strut / Twin tube STEERING Type / Power Source Motor Driven Power Steering (MDPS) Steering ratio 12.8:1 Turns, lock-to-lock 2.5 Turning circle, curb-to-curb (ft.) 34.8 ft. BRAKES Type front/rear Ventilated Disc / Solid Disc Size (in.) front/rear 12.0 in. / 11.8 in. Booster Type Electric Booster (Regenerative Brake) Regenerative brake Motor polarity reversal Parking brake Electric Parking Brake (EPB) WHEELS/TIRES Wheel size (in.) 7.0J x 17 Alloy Tire size P215/55R17 Spare Tire Tire Mobility Kit (TMK) CURB WEIGHT Curb Weight, min (lbs.) 3,715 GVWR Gross Weight (lbs.) 4,806 TOWING CAPACITY Towing Capacity Not recommended
Huh. I suspect it may have something to do with the delay. The new Soul EV isn't coming to the U.S. until next year now.
