Since the Ioniq 5 seems to have only 1 USB port for both Android Auto and USB music, has anyone found a USB splitter that works for both? I've tried a couple of splitters and they don't recognize either the USB flash drive for music or the phone for Android Auto. Appreciate the lead if anyone has gotten this to work. Thanks.
It probably wont work as in the home computer/linux world, a USB port is identified with a unique device number. Lets say this is DEVICE 1 You plug in a PHONE to the USB port and it would be identified as DEVICE 1.1 You unplug it and plug in a USB memory card with music. It is identified as DEVICE 1.1 You unplug the USB memory card and plug in a USB HUB (splitter). It is identified as DEVICE 1.1 You plug in your PHONE in first port of the hub. It is identified as DEVICE 1.1.1 You also plug in your USB memory card in second port and it is identified as DEVICE 1.1.2 They probable didnt code the headunit to handle/expect more than 1 device on the USB port *But I could be wrong
