I'm getting a popping noise when accelerating from a dead stop. it is not consistent. I did get new wheels and tires recently. Here is a video of the sound https://photos.app.goo.gl/VzC7rmPWGGiToNur7
Definitely doesn't sound right... Have you checked the lug bolt torque? If you brake hard does it make the same noise?
Is the sound coming from only your front wheels? Hmm to my ear it sounds like the torque of the electric motor is torqueing the lug nuts of the wheel upon acceleration. Maybe check if they lug nuts are torqued to factory specs.
That sound is reminiscent of a brake shield metallic clang or hand brake holding a little and then releasing
Ok so I took the wheel off, inspected it. Reinstalled the wheel and torque to spec. Now the noise is gone. So it's the equivalent of "turn it off and turn it back on".
Now loosen the lug bolts and see if you used less force. Them torque em. Should have torques them before doing anything to confirm or eliminate that as a possible cause
