Coolant Change, 2020 Niro EV
Discussion in 'Kia Niro' started by snowy2020, Apr 27, 2022.
  1. jm31828
    jm31828 New Member
    In a lot of ways I know Tesla has ironed out some of their issues and don't have much in the way of maintenance (and things like coolant are much cheaper to replace than they are with Kia)- but I worry about other issues with them, like the control arm issues that seemingly are a problem with the Model 3 (and Model Y).... so I think the grass is not always greener on the other side.
  3. RGOLD
    RGOLD New Member
    Actually, I got a brand new '23 Tesla Model 3 back in January as a second EV. Looks like the control arm issue happen with the early M3 models and should be resolved now. The only "real" maintenance items in the book are brakes fluid moisture check every two years and tire rotation every 5K miles...
  4. jm31828
    jm31828 New Member
    Oh, thanks for sharing! I have actually been so curious to hear from anyone who has had both a Niro and a Model 3 to see what the differences are.
    Glad to hear the control arm issue seems to have been resolved. How are you liking the '23? And is it the base, RWD model?
    The other gripes are of course fit and finish issues, the interior feeling cheap or being loose or squeaky... any of those issues on yours? Overall, quality-wise- what is your take compared to the Niro?
  5. RGOLD
    RGOLD New Member
    It’s base RWD. I inspected the car meticulously on the delivery day and it was flawless. No squeaks and rattles yet. The interior is good for $37K (after federal tax credit and state rebate), no complaints here.
    I prefer a car with buttons and switches to control things, but I have learned and adapted to the minimalist cockpit.
    Overall Model 3 is much more fun to drive, the phone app to control the car is excellent, the car itself got 4 software updates since I got it. It added new features and improvements.
    Tesla Charging network is plug and play vs. CCS that is plug and pray…
    The base model comes with LFP battery that can be charged daily to 100% (271 miles range) so no worries about 80% charging.
    I was looking into getting a ’23 Niro EV Wind, but $47K with dealer mark ups, no tax credit and slow (70 kWH) and unreliable DCFC network, got me into a Tesla.
  6. jm31828
    jm31828 New Member
    Thanks for sharing! Glad to hear it's been such a positive experience.
    Are you able to actually get the full advertised range (or more) if you drive it modestly on trips?
  8. RGOLD
    RGOLD New Member
    On a warm day, at 60 MPH, the computer show consumption of around 4.8 miles per kW, so with the 60kW battery the range should be 288 miles.
  9. jm31828
    jm31828 New Member
    That's fantastic!
    Any other issues at all with fit and finish, odd noises, any of the problems that we hear about in some of the discussion channels?
  10. jm31828
    jm31828 New Member
    Interestingly, out of curiosity I called the Kia dealer where I bought mine, asking what they charge for the coolant flush/replacement. Keep in mind that they sell and service a lot of EV's- but he had no pricing on that, said this is not work they have ever done there.
    That seems odd considering the fact that this is recommended on a pretty frequent basis at 37,500 miles!
    At some point I guess I'll call one of the other major Kia dealers in my metro area to ask them- but it's not a pressing matter for me since mine is only a year old with just under 6,000 miles so far.
  11. snowy2020
    snowy2020 Member
    Yes. It’s only been a day to verify that it’s fixed, but I just had a recall done on it for this issue and the warning light is gone. It took them all day, but they said what they needed was a new machine that flushes the coolant. Whatever they were using previously cause debris to enter into the lines which cause the alert. This is just what the dealer told me. New machines are going out that fix the alert and reflush the system. Hopefully this is a permanent fix, but as of now my alert is gone.
  13. iTest1
    iTest1 New Member
    Has anyone tried doing this on their own?
  14. This apparently is the machine issued to dealers to carry out this procedure.
  15. iTest1
    iTest1 New Member
    Hmm... Looks like any fluid exchanger with a pump. Wonder where the plugin the lines.
  16. insightman
    The full photo:
  17. snowy2020
    snowy2020 Member
    Update, losing coolant, recall didn't work, light still comes on every time even with the coolant tank full, I'm now out of warranty and they'll no longer cover any repairs.
  18. Harris_L_EV
    Harris_L_EV New Member
    I’ve just brought my 2019 eNiro into my local shop for the 25k service. The service manager said there is a recall for swapping out the pink coolant for a reformulated blue coolant. This, apparently, is the second or third reformulation. The shop manager said they think they have this problem figured out. Apparently the pink and older blue coolant was crystalizing and the pump wouldn’t/couldn’t pass the fluid through the piping. I’ll see what happens and post an update in the next week or so.
  19. snowy2020
    snowy2020 Member
    Interesting. Is the "old" blue coolant he is referring to the BSC1? When I originally had my 37k fluid flushed I don't know what formulation it used. Later for the recall (and going forward) they are definitely using BSC2.
    As far as I can tell, it doesn't work. BSC2 still results in the light after repeated flushes with it. Unless the older coolant did a lot of damage. Maybe once it's crystalizes, there's no way to remove it. The system is just completely gunked up? That would explain why after EVERY flush the coolant level continues to drop for a couple of weeks (I've had it flushed 4 times now and it does the same behavior every time). It's slowly working its way through blocked passages. Just thinking out loud.
    Let us know what happens! My 2020 has been back in the shop for 3 weeks now while they try to figure out what to do next.
  20. Harris_L_EV
    They are replacing the pink coolant with the BSC2 fluid. I didn’t have any alerts so I’m hoping that this won’t create a problems. I’ll update in a couple of weeks.
    snowy2020 likes this.
  21. In Hyundai's world the "pink" coolant is a conventional type. Early Kona EVs made up to May 7 2019 had green conventional coolant while later production up to May 17 2021 used the BSC1 blue low-conductivity coolant. Further production used the BSC2 coolant. All Kona up to May 17, 2021 with BSC1 are being changed to BSC2.
    Early Konas (like mine) that got the traction battery replaced under the recall were topped up with pink coolant which was the updated conventional type replacing the green. With a mix, mine now looks red.
    I'm not familiar with Kia's application in the Niro but I find it unexpected that one with pink coolant would be considered part of this campaign, nor has it been mentioned in other forums.
    Another point of interest is that the 2023+ Niro EV has a conventional pink coolant. That's due to the battery cooling panel being moved to the outside (underside) of the housing so that it's not possible for leaking coolant to 'wet' the cells.
    jm31828, iTest1 and snowy2020 like this.
  22. snowy2020
    snowy2020 Member
    According to the TSB PS621 from Kia, the only 2 coolants used in the Niro was the conventional green (early 2019 models) and the low-conductive blue (later 2019 and 2020-2022). Which is confusing why Harris has pink coolant. Now the 2023 is going back to pink? Redesigned cooling trays? And 2 formulations of the blue low-conductive coolant.
    SA512 is the coolant flush that's supposed to solve the issue of the phantom light. There was another recall regarding leaking coolant into the BMS (or another electrical component) that was only issued for a select number of 2020's AFAIK. Anecdotally, when I got the SA512 done the first time, the original instructions with the recall given to the dealer were wrong...when I brought it back, they did a completely different procedure with the same machine...supposedly the recall is a multi-day process. But others are getting the recall done in a single day. Of course even the multi-day process didn't work on mine.
    I'm just getting my info from the techs and service managers, but it really sounds like Kia doesn't have a clue what they're doing at this point.
    iTest1 likes this.
  23. jm31828
    jm31828 New Member
    This is all definitely frustrating.... not so much the fact that the issue exists (though that is frustrating as well, when other EV's don't have these issues), but the fact that Hyundai/Kia can't seem to even get clarity on what's going on and what the true permanent fix needs to be.
    I have a 2022 Niro that only has 7,000 miles on it- so I suspect I am still quite a ways from experiencing any issues with this, and of course am a long ways off from needing my first scheduled coolant flush- I am hoping they have all of this sorted by the point that I need any of this work done.
    I can only imagine what a mess this all might be if it persists and gets worse after the warranty expires.
