When I plug in I get the usual blink of green on the charger LED then nothing. Then I tried a neighborhood level 2 and the same. Ran car around a bit in HV Charge and battery charged up no problem. Anyone seen this and / or have a hack to fix??? Sent from my iPhone using Inside EVs
Check your HondaLink app. You probably have a scheduled charge set. You can also override it by holding down the 'HOLD' button on your key fob for about 2 seconds. You'll get a long beep, then charging will commence.
The Driver Information Interface of your Clarity tells you about the timer setting when you turn off the car.
