Car is not charging due to an interruption
Discussion in 'Bolt EV' started by racerx2005, Feb 15, 2019.
  1. racerx2005
    racerx2005 Member
    Hi there, I’m getting the message below every so often but sometimes the car is charging just fine; other times is really a failure.
    “OnStar: Your 2019 Bolt EV is not charging due to an interruption. Please check your vehicle. For help, call 1.888.466.7827. Text STOP to cancel.”
    Does anyone have an idea what this is? also I’m rarely getting the text when the charging is completed (got it once since 12/15); my settings is correctly set up though.
    Thanks
  2. Sibilance
    Sibilance New Member
    It would probably help to mention which charger you are using, voltage etc. Does the circuit share load with anything else, and so forth.
