Those days I noticed a bad smell being in reverse & uphill (under these circumstances only). The smell is chemical, fish like and dissapear after some time ~ 1h. Any ideas? Thanks
Perhaps the AC condensate drain is plugged and when that mouldy water is swished around it becomes more aromatic. Any mechanic should be able to clear it.
Mine drains through a hose left center (passenger side by the HVAC) near the firewall, and should be easy to trace and clear https://www.insideevsforum.com/community/index.php?threads/seeing-reports-of-a-kona-recall-in-form-of-software-update.8713/page-8#post-102295
Do the reverse/tail light(s) come on normally? A flicker that could point to a loose connector, the insulation might be melting and may have caused the circuit to burn open now the resulting smell to stop. Just a thought.
Yes, it's working. I will report this issue to the dealer and I keep you informed. Otherwise a perfect car, here in Iasi I got a 6.8 KWh/100 on heavy traffic.
