The EVSE supplied with my MME GT is plugged into a 240V outlet. I leave it plugged in between charging. I just noticed the led light has changed from blue to yellow (amber) but it's not plugged into my MME, just sitting idle. It is cool to the touch and my 50 Amp GFI breaker has not tripped. So what does this mean and how do I fix it?
The yellow means there is a fault that requires troubleshooting. Ford recommends that you unplug the connector cable from the EVSE and replug it in securely. They have a sensor on that plug. If it persists, they say to try a different plug.
