Trunk would not lock
Discussion in 'Clarity' started by bobcubsfan, Jul 24, 2018.
  1. bobcubsfan
    bobcubsfan Active Member
    An odd thing happened yesterday. Put some items in the truck. Closed it. Would not lock. Tried several times. Drove off. Warning: Trunk Open on the dash. After driving a few blocks, with the trunk going up and down, it finally locked on its own. Cannot repeat the behavior.
  2. Timothy
    Timothy Active Member
    Were you driving downhill with a full battery at the time?
    weave and lorem101 like this.
  3. bobcubsfan
    How did you guess?
    Johnhaydev likes this.
  4. insightman
    insightman Well-Known Member
    You're a good sport to withstand such cruelty without lashing out!
    Just out of curiosity, did you try moving your key fob far away and returning without it to retry locking the trunk?
  5. Clarity Dave
    Clarity Dave Member
    I've had the trunk refuse to close when I was trying to shut it with the hand holding the key fob (because it thinks I might be shutting the fob into the trunk, presumably). After moving the fob to the other hand or my pocket, it shut on the next try. Could it have been something like that?
  6. bobcubsfan
    You gotta have a sense of humor. No. But as I said, when I was driving, the trunk slammed shut. My wife suggested that I lock and then unlock the car. If that happens again I will try it.
  7. bobcubsfan
    Could be. If it happens again I will try that. Thanks.
    John Lilly likes this.
  8. bfd
    bfd Active Member
    Car's possessed. Like Christine
  9. FlaDave
    FlaDave New Member
    Yesterday, I took things out of my trunk and shut it before heading up to the office. When I came back down, the trunk was not shut all the way. I closed it with a little more force and it latched properly. I assumed that I had not pushed it hard enough the first time, but I'll be paying closer attention to this now.
  10. bobcubsfan
    Problem solved. I had tossed my wife's purse in the trunk. Her key was in the purse. So, the system probably assumed I had left the key in the trunk, which I did.
    Uye47, lordsutch and weave like this.
  11. weave
    weave Active Member
    Thanks actually encouraging. I've locked my keys in the trunk before (of another vehicle)
  12. bobcubsfan
    We were on a trip recently. A tourist locked car keys in the trunk. A rental. No phone service. After about an hour's work, he was able to get the doors unlocked using a long metal rod. But, no access to trunk. Someone had to pull out a back seat to allow access to the trunk. So, thank you Honda, and probably others, for the safety of preventing keys to be locked in the car.
  13. Viking79
    Viking79 Well-Known Member
    Exactly, I was going to suggest you might have put a bag in the trunk with keys. It gets really unhappy about that and refuses to lock :)
    Glad you got it figured out. I do that about every other time I drive the car.
  14. bobcubsfan
    Unrelated, but when both of us get near or enter the car at about the same time, the computer can get confused. In another thread, there is talk about multiple beeps when walking away. We just need to be aware and be sure to lock the car with the key if that happens.
  15. insightman
    So the trunk locked itself as you were driving around even though the fob in the purse was still in the trunk?
  16. bobcubsfan
    Yes. The trunk lid bobbed up and down and finally slammed shut and locked.
  17. MikeB
    MikeB Member
    Different but possibly related.... If I approach the trunk expecting it to unlock with key fob in hand that reaches for trunk latch, it will not unlock. Key fob must be a foot or so away from trunk for trunk to unlock.
  18. bobcubsfan
    Hmmmm. Proximity sensor? I usually use the manual latch on the trunk not the key fob. Sometimes will release trunk from inside using the switch near the door.
  19. bobcubsfan
    Confirmed. I tossed my wife's purse (not my wife) in the trunk. Her key is in her purse. My key in my pocket. The trunk would not latch until I took her purse out of the trunk.
  20. Steven B
    Steven B Active Member
    Side note: If you put one of those jackets over your key fob, its effective range will diminish slightly.
