Switched Reluctance Motor
Discussion in 'General' started by bwilson4web, Jun 19, 2023.
  1. bwilson4web
    A basic educational video, it explains something I'd read about but not understood:
    • High torque at low rpm - very nice for getting off the line. But at higher rpm, PM motors can generate significant reverse voltage limiting the current.
    • Low reverse EMF at high rpm - the rotor field magnetic fields become an inductive motor by effectively cancelling some of the PM fields.
    The correct term is "Internal Permanent Magnet Synchronous Reluctance Motor." I knew Toyota had them in their transaxles but did not understand the physics.
    Fastnf likes this.
  3. hobbit
    hobbit Well-Known Member
    The Toyota papers and "new car features" doc mentioned field-weakening a lot, because it was important
    for keeping back EMF from exceedimg battery voltage through the IGBT back-diodes. I think this was
    still in play when coasting in neutral, which explained how several of my experiments didn't blow things up.
    It also explained why flat-towing a Prius with the inverter power off was a bad idea.
    _H*
