Small issues/quirks
Discussion in 'Hyundai Kona Electric' started by Brennan Raposo, Mar 10, 2019.
  1. It's a complete puzzle to me as well as to why they didn't integrate a 4th regen level incorporating full one-pedal stop and hold capability. Perhaps someone in SW engineering got confused between "pedal" and "paddle".
    It's interesting to me that the left-paddle-hold function uses resolver-based servo positioning to maintain a stop while the Auto Hold function actually uses the disk brakes. I would subsequently expect that slightly more battery power is used while holding the motor in position than if it can relax at zero torque with brakes on.
    If you play around with the former on gradients you'll note the deadband. It fails to work in reverse as well but no-doubt that's for safety as you continue driving.
  2. Thought I would add a couple:
    (1) When resume driving (touch keypad or foot pedal) after stopped in SCC and following a semi, the car pauses every time the semi switches gears, it basically matches the acceleration pattern of the truck in front, which I find hilarious - but the car behind me doesn't.
    (2) The callus on my left knee from applying intermittent adjustments to the steering wheel ( ~ every 20 seconds when using SCC). Wish there was a way to increase the duration between check times. If you let the SCC give you the LKA boot (ping), it will reacquire but only adds about 5 seconds.
    mho likes this.
  3. Do you have this setting and have you tried a slower response?
  4. That would probably help as it is set to normal. I'll give it a shot, thanks.;)
    mho and KiwiME like this.
