Rust proofing a clarity
Discussion in 'Clarity' started by len zaifman, Apr 4, 2018.
  1. len zaifman
    len zaifman New Member
    We have received conflicting advice on whether or not to rustproof our upcoming (hopefully June) Clarity.
    1) We live in ottawa ontario - lots of snow and salt
    2) we hope to keep it 10+ years
    Do most people in cold high salt areas rust proof the car?
    Do you use No drip rust proofing or the electronic module? I have heard both only electronic module works with an Ecar and only non drip works with an Ecar(Electric car)
    Any experience?
  2. lorem101
    lorem101 Member
    Dealer I went to recommends not rust proofing (electronic module is ok). I don't think I'm going to do it when I get the car.
  3. Atul Thakkar
    Atul Thakkar Active Member
    When I bought my Toyota back in 2007 , it had installed a corrosion protection machine. How it works is that It produces -ve charge in the body of car. It worked very good for me so far ( I am on year 12) with almost no rust. I have not done rust proofing on that car ever. I was wondering to transfer that on my New future clarity. I pad around $ 500/- 12 yrs ago.
  4. Timothy
    Timothy Active Member
    I'm pretty sure your Toyota stayed mostly rust free because it was a well built car. I'd leave the device off your Clarity.
    https://www.theglobeandmail.com/glo...l-an-electronic-rust-inhibitor/article535224/
    AlanSqB likes this.
  5. Gearhead
    Gearhead Member
    Per Consumer Reports dealer applied rustproofing is a mistake. Manufacturers do a fine job these days. You'll just add weight reducing MPG.
    AlanSqB likes this.
  6. PHEV Newbie
    PHEV Newbie Well-Known Member
    Nearly all the body panels in the Clarity (all except the rear fenders) are aluminum as is much of the suspension and some structural components. The structure of the unibody is mostly high strength and ultra high strength steel but it is protected from spray and salt by all the cladding underneath (that was put in for aerodynamics--only the new Acura NSX supercar has similar panels among Honda cars). The Clarity is already one of the most rust proof cars in existence. After market rustproofing will likely do more damage than good.
    V8Power and AlanSqB like this.
  7. V8Power
    V8Power Active Member
    Yes, also there's alot of high voltage gear and electronics all over the place so the oil-based annual rust proofing sprays like Krown might impact. Krown was fantastic for our previous all-steel cars, Odyssey & Lexus GS, they went 15 years without any rust and Krown guaranteed for the lifetime of the car no rust perforation if treated annually from the first 30 days on the road.
  8. Atkinson
    Atkinson Active Member
    I can't figure out how you would rustproof this car.
    Looking underneath, there are so many covers the length of the car, the battery, cooling and electrical lines, etc.
    Best I can hope for is to flush out the undercarriage every Spring.
    Another thing I noticed was a fair amount of rust on the nuts and bolts under the car as well as the side seams of the steel cover plates under the car.
    I bought the car in June, so I haven't driven through salt yet.
    Remarksman likes this.
