Odd smell when charging while driving
Discussion in 'Clarity' started by Timothy, Feb 16, 2018.
Tags:
  1. Timothy
    Timothy Active Member
    Our Clarity has been great. One concern is an odd smell when using the feature where you hold down the HV button to charge while driving. We have only done this twice, but each time has led to an odd smell. Any one experience this or have any advice? Thanks.
  2. Viking79
    Viking79 Well-Known Member
    If you want to be safe you could have the technician at the dealer check it out, but most likely it is stuff burning off the engine. If it doesn't go away after running the engine for a while (maybe 1 hour of run time?), it could be a leak of some kind, but usually you get some bad smells from engines when running them the first time, or after a prolonged period. You might notice it if you don't use the engine for the next 6 weeks and run it again for a bit.
    An issue with hybrids is they don't get warm enough all the time to burn crud off, so the charge mode will likely load the engine more and cause it to burn stuff off. That smell should go away when everything has burned off.
  3. css28
    css28 Active Member
    My Volt smelled "hot" after each ICE run for several weeks. There was no problem.
  4. barnesgj
    barnesgj Active Member
    My Clarity had an oder when I first ran the ICE. It went away after a short time and has not returned.
  5. AlanSqB
    AlanSqB Active Member
    Same. I had to run it home on the ICE all the way from the dealer because it had not been charged. Smell went away after about 30 mins.
