New Clarity owner and his dumb questions
Discussion in 'Clarity' started by Alex800st, Feb 24, 2020.
  1. insightman
    Kerbe, KentuckyKen, Sandroad and 2 others like this.
  3. Sandroad
    Sandroad Well-Known Member
    Or, maybe even better, continue questions in an existing thread on the topic! ;).
    Alex800st likes this.
  4. Yes, follow up questions that relate to the original topic is what creates a thread. Going “off topic” is generally frowned upon.
    What is the topic of a thread that asks a series of random questions?
  5. Randomized Help Thread.
    Personally I love threads like this because there are always some surprising subjects that arise. They work more like my brain than strict "on one subject" threads.
  6. Geor99
    Geor99 Active Member
    I agree with your post almost word for word.
    Friendly Advice: Throw in some paragraph spaces, as it is much more pleasing to the eyes and easier to read than 1 super long paragraph with no breaks.
    Im not trying to be an ***.
    Robert_Alabama, Kerbe and Mowcowbell like this.
  8. Alex800st
    Alex800st Active Member
    My charge timer in the car set for 1900, when we have lower rate. Today I came home 1930, plugged in - not charging. I guessed that if I plug after the time in settings, car will wait for that time to come - which will happen tomorrow. So I removed the timer and it started to charge. Am I correct with my assumption?
    Also is the a way to keep the car charging and providing heat for the person who is sitting inside that car?
  9. You are correct. It only starts charging on timer if it's plugged in at the start of the session. Been there, got confused, figured it out.
    Not sure, but probably not. iirc you cannot charge if the car is running. I don't think you can get heater if not running. Someone who lives in a cold clime might correct me. Being on Las Vegas I have never run the heat.
  10. insightman likes this.
  11. rodeknyt
    rodeknyt Active Member
    You can leave the charge timer set all the time. If you need to charge at any other time, just press and HOLD the charge button on the fob AFTER you plug the charger in. It will start charging immediately.
  13. Alex800st
    I just unpacked original evse that came with the car. Sticker and manual says “110v 12A”, nothing about 240v. Another thing - plug on the evse is 15A (two small parallel blades, just like any other household device). Not 20A, two blades 90 degrees to each other. Is it still going to work on 240v?
  14. Mowcowbell
    Mowcowbell Well-Known Member
    Yes, mine says the same thing on the back of the evse itself. The J1772 end in very faint letters lists voltage 120-277v.
    The unit was manufactured by Panasonic and is identical to the evse provided with the Toyota Prius Prime. Plenty of those owners are running their units on 240v without issues.
    The plug itself is of the 15A type... I went with the NEMA 5-20 receptacle to keep my modified cord at 20A at all connections. It does not get more than 10F above ambient temp of my garage, even when my garage is baking in 90F heat in summer.
  15. Kerbe
    Kerbe Well-Known Member
    Interesting - I thought the manual was available only on CD.
  16. Expect the paper copy to take a while to get to you.
  17. Would you consider that a Level 1.5 charger?
  18. Kind of an artificial construct, this Level 1/Level 2 business. In the UK and Europe, house voltage is 240V. So do they all have Level 2 by default?
    My late Volt could only charge at 3.3 kW due to its onboard charger capacity. Most consider that Level 2, but in truth the Clarity EVSE could probably accomplish that if fed 240V.
  19. There’s noting artificial about a 12 hour charge time or a 2.5 hour charge time.
    Utilizing adapters to provide 240VAC to the Honda provided EVSE appears to charge at ~3.3kW. Hence the 5.5 hour charge time. The PHEV Clarity has an onboard charger capable of charging at 6.6kW with the appropriate L2 EVSE.
  20. Alex800st
    Do you use recommended tire pressure or higher? Why?
  21. I run my cars about 4 psi higher than recommended because I like the higher efficiency and don't generally find the ride quality too harsh.
  22. So you'd like to make up a new name for it.
    Fine.
  23. DucRider
    DucRider Well-Known Member
    The OEM EVSE will still be 12A. 12A @ 240V = 2.88 kW.
    For some reason the 3.3/6.6 spec is for the older 220 V standard. In reality, the EVSE communicates the amps it can supply and the voltage will dictate whether it is 3.3 or 3.6, 6.6 or 7.2, etc
