How to increase screen resolution (requires root)
Discussion in 'Honda' started by Arctiic, Jul 8, 2023.
  1. DISCLAIMER: I will not be held liable for any damages or bricked head units as a result of any attempt to reproduce the following. Proceed at your own risk!
    While messing around in ADB, I found where the screen resolution values are stored (allegedly) persistently:
    • Connect to vehicle via ADB (default port 5555 for wireless)
    • Enter `adb shell`
    • `su`
    • `cd /data/property`
    • `busybox vi persist.sys.NV_DISPXRES`
    • input `i`, then delete default value `800` and replace with `1600`
    • input `ESC`, then `:x`, `ENTER`
    • `busybox vi persist.sys.NV_DISPYRES`
    • input `i`, then delete default value `480` and replace with `960`
    • input `ESC`, then `:x', 'ENTER'
    • `input keyevent 26` (screen should turn off)
    • `input keyevent 26` (screen should turn back on)
    • If above doesn't refresh, exit the shell terminal and try `adb reboot` (or just reboot the unit manually)
  3. coutinpe
    coutinpe Active Member
    That's a worthy endeavor indeed, thanks! Can you post a picture of the result?
