My Honda dealer in Ottawa did the replacement. (Civic Motors Honda) Posted the following on a previous windshield replacement thread... My dealer ended up invoicing my insurance $3100.00 CAD!! (minus $500.00 deductible paid by me to dealer). Edit: BTW, incase anyone was wondering, my insurance rate went up when renewal time came around. I am guessing it was due to my windshield replacement as I haven't gotten any tickets.
I have allways kept superglue in the glovebox since this will work prety good. I think this is what auto window experts use to patch chips. Always seems to spider out quick so I try to get it glued quick. Last time I used wa son side window when rock hit it. Seems to work and saves $$$ on insurance. Edd
No disrespect intended but I don’t suggest this practice. Super glue is definitely not what the glass places use. And if you do use superglue or one of the DIY kits found in auto part stores, the contamination will prevent any future professional repair from working properly. And most insurance companies in the US do professional chip repairs for free. Even if yours doesn’t it’s only about $50 to just pay out of pocket. The pros will first grind any loose pieces out, then put the damage area under a suction vacuum to suck all air out of the crack, then utilizing that vacuum they release non-yellowing UV resistant resin into the chip and the vacuum forces it far into all radiating cracks. Then they put it under UV light to cure the resin.
I thought all modern windshields (and maybe all the other glass in cars) were pieces laminated together. This to keep the glass pieces (although less sharp due to tempering) from becoming projectiles.
Indeed yes all windshields are laminated. There's just a different material inside the sandwich for Acoustic: https://bettersoundproofing.com/how-to-tell-if-you-have-acoustic-windshield/
Exactly the same happened to me a couple of weeks ago. There is a barely visible tiny little crater near the lower passenger side so I just ignored it.
No ofence taken. I shoulda explained a little more. Alot of dings on glass I see are the size of a watermelon seed or smaller. These are the chips I was thibnking about. Not worth to get fixed by glass expert but super glue will fill the ding anf prevent problems. The dings bigger than a nickel with spider legs already will be fixed by the glass experts. Always learn alot on here from the folks who know.
