falsely high HV ranges
Discussion in 'Clarity' started by ringf4g4plugin guy, Sep 4, 2018.
  1. ringf4g4plugin guy
    ringf4g4plugin guy New Member
    Kyle raised this question back in Jan, 2018.
    Has it ever been resolved.
    I just topped my fuel tank for the first time with 2.5 gals and the range came up over 700 miles.
    Local dealers service center does not know how to fix it.
    Bernie
  3. David A
    David A Guest
  4. LegoZ
    LegoZ Active Member
    Not if the dealer didn’t know about and apply the fix. Can you determine when your car was built?
  5. KentuckyKen
    Doesn’t matter what the build date is since no one has reported that their Clarity came with the update. Have your dealer install Service Bulletin 18-069 (J-20-18 for Canada) to fix the erroneously high HV range estimate. It probably won’t pull up on his computer by using your VIN. Have them search by the SB #. It’s for all VINs.
  6. To remove this ad click here.
