Explaining Full Self Driving to a new driver
Discussion in 'General' started by bwilson4web, Jun 27, 2023.
  1. bwilson4web
    The best way to explain Full Self Driving (FSD) to a new driver is "It is a toddler."
    PHANTOM BRAKING
    These often reproducible, uncommanded, sudden braking events are often due to stale Google Maps showing long gone construction zones.
    UNCOMMANDED TURNS AND LANE CHANGES
    Regardless of turn signal or up coming turns, it will insist on turning the wrong way or changing to the wrong lane. It will actually come to the intersection and suddenly, abruptly change lanes in the middle of the intersection.
    NAGGING
    Even if your hand is on the wheel, it is either too light or too heavy and we're not going to let you know where it is in the range. With other cars a half a mile away, you looked at the impossible navigation map too long.
    IGNORING OPEN ROADS AND TAKING PRIVATE ROADS
    Even if the map shows the road, it won't take the shorter route. Instead, it will try to take a private, close road found on the Google Map.
    LONGER, HIGHER SPEED ROUTE NOT SHORTCUT
    Navigation will drive twice as far at twice the speed as taking a slower, more efficient, same time route.
    NO MEMORY ... ARTIFICIAL INTELLIGENCE
    Like the movie "50 First Dates," the car has no memory of corrective action or preferred routes. Each drive is a totally new experience with no memory of past problems.
    REVERSE POLISH WAY POINTS
    If you want to enter way points on a route, use reverse Polish notation. You stack the way points from the destination to your current location.
    If you approach FSD like it is a toddler, you'll do OK. A work in progress, it has gotten 'less bad' but still a handful.
    insightman and andyG59 like this.
  3. marshall
    marshall Well-Known Member
    Wow. I would have thought they would have weened themselves off Google Maps by now.
    bwilson4web likes this.
  4. bwilson4web
    With 1-2 million Teslas on the road, one would have though they would have harvested trip images along with driver inputs to make their own, super map that exceeds Google Maps somewhat lethargic to update ones.
  5. hobbit
    hobbit Well-Known Member
    > ... would have harvested trip images along with driver inputs ...
    ... And that, boys and girls, is one major reason why I don't own a Tesla.
    _H*
