v1.4 now available Changes for v1.4 fixed cost for kwh not parsing fixed max temperature display (was showing min) fixed pack size (39/64kWh) recognition for Kauai/Niro upgraded db to v5 added edit cost kwh for trip card added set cost kwh backwards for settings option several other fixes and adjustments Premium version, all the above plus: added NearBy screen autoupdate option added sync data option Biggest change is for the premium version where the sync data option is now available. In order to sync data to the web server do as follows (see attached screens): 1. activate the option in the settings menu, 2. agree data uploading, 3. go to the website sign up page (blue link in the dialog box) and register there providing your NetId code that was copied to the clipboard by the App. 4. verify your email. Then from the App make sure you are connected to a data network and hit the "Sync Now" option in the App's menu to force to send the data on normal usage this is actually not necessary as the App will try to sync several times by itself during operation). Now log in to the website: https://evwatchdog.net, fill any missing info in your profile, read and agree with the terms and you're in. You should see all your data there plus other interesting graphical and tabular analysis. FAQ here: EV Watchdog Android monitoring App - FAQ And be sure to join the dedicated fb group where I share all the developments: Facebook Groups
v1.5 now available Changed capacity calculation for battery card (now uses nominal voltage) Upgraded db to v6 Added "Go!" button in charging station details for Maps* Added charging mode Added glide and regenerative braking distance Several fixes and adjustment for charts screen* Several other minor bug fixes and adjustments * premium version only Added charging mode which shows remaining time (to 100%), charged kWh and instant charging kW Added glide and regenerative braking distance New "Go!" button in the charging station details which will open Maps and set destination More info on the website: https://evwatchdog.net FAQ: EV Watchdog net: https://evwatchdog.net/help/faq.php Download: EV Watchdog net: https://evwatchdog.net/app.php FB group: Facebook Groups: https://www.facebook.com/groups/ev.watchdog
