EV travel charging
Discussion in 'Clarity' started by Danks, Apr 5, 2019.
  1. jdonalds
    I agree. Even if you identify charging stations on your path forward when you arrive they may be busy. It's not like gas stations where we wait for 10 minutes while the car in front fills their gas tank. Recharge times on BEVs can be quite long.
    For me I'll upgrade from PHEV to BEV when BEV charge times are less than 15 minutes and there are ample charge stations. I believe it will be a few years before both of those happen.
    fotomoto and Skip Bacon like this.
  2. Robert_Alabama
    I'm not sure why we've made this thread into something the original poster wasn't suggesting in the first place. Here's the post to clarify only 1 hour after the original post...
    If free charging is available at locations one is already visiting and truly requiring no extra time or effort, then there is no reason not to take advantage of it, other than potential mischief if you use your own 120V EVSE. The OP wasn't planning to go out of the way/spending extra money/time/resources to charge as compared to burning gas.
  3. I think a useful fact that hasn’t been mentioned yet is that the EVSE handle has a security pinhole to thread a cord lock through which would prevent anyone from disengaging it from the vehicle. I have a luggage lock but the cord seems to be a little too thick so I’m not yet sure what exactly fits, but I’m sure someone here has a link to something.
    Texas22Step and Danks like this.
  4. The Gadgeteer
    The Gadgeteer Active Member
    Don’t rule out 120 volt overnight charges that will charge most of the battery. If you park by 9 PM and leave at 7 am that’s 10 hours of charging which is about 40 miles/80% charge.
    Sloanhoo and Danks like this.
  5. MNSteve
    MNSteve Well-Known Member
    Exactly my philosophy. I am not going to be a slave to charger locations, or even spend a lot of time researching, but "charger available" does go into my choice matrix. It's as much to encourage the industry to make the facility available as the actual charge.
    And I would like to second another comment in the thread . . . please folks, get permission before you just plug in to that outlet in the parking garage to charge. This is rather the opposite of trying to encourage establishments to provide charging by using it. Just because there's a plug on the wall does not mean that it's there for you to pull a significant load for a significant time; we don't need people justifiably blaming us for blown circuit breakers,
    Sloanhoo, insightman and Danks like this.
  6. One further point could be made here: charging infrastructure availability, cost of electricity and cost of gasoline all vary quite a bit depending on what part of North America you are traveling through. The West Coast Electric Highway project has put a much higher number of free or low cost charing stations along I5 from Border to Border, and electricity is cheap relative to gas prices. As a result, my road trips from Portland to Vancouver BC are definitely going to have some stops for charging/lunch, as well as the major fast charge station (free) that the government of BC has installed at the Community Centre across the street from my daughter’s house. Heading to Alberta this summer, it looks like I could get some EV love along the way courtesy of BC/Alta government projects, but I am also getting very excellent gas mileage in case that doesn’t happen. With gas prices in Canada being what they are, it makes more sense to put effort into EV charging.
  7. Again, the economics depends on where you are. We blue staters on the West Coast have subsidized some of the charging options to encourage EV use. It’s much less expensive than I thought it would be. Also, my utility makes charging at home at zero dark thirty practically free, so I don’t mind convenience charging now and then on the road.
