EV Range Calculator
Discussion in 'General' started by plg, Mar 13, 2024.
Tags:
  1. plg
    plg New Member
    I created a new app for the iPhone that calculates the range of any EV according to efficiency and battery size. It is easy to use and available on the Apple Store free of charge.
    https://apps.apple.com/us/app/evrc/id6478421298
    Features:
    EV Range Calculator for all EV cars and trucks. Perfect for trip planning and knowing when to unplug the charger and get back on the road. On the road you can quickly calculate what efficiency is needed to reach your destination. Adjusting to a lower speed improves your efficiency, and assures you that you will arrive without range anxiety. EVrc is simple to use and quickly will confirm any range estimate for stress-free EV driving.
    bwilson4web likes this.
  3. SouthernDude
    SouthernDude Active Member
    Will it be released for android too?
  4. insightman
    Is it like @GvilleGuy's app from the MINI Cooper SE forum?
  5. Puppethead
    Puppethead Well-Known Member
    I looked at it and this EV Range calculator seems to be for planning ahead, whereas @GvilleGuy's iPhone shortcut is basically a log book of completed travels. So two different, but useful, things.
  6. plg
    plg New Member
    Yes, there is an Android version in development. Hopefully soon.
  8. SouthernDude
    ok cool
  9. plg
    plg New Member
    Free App in the Apple Store.
    Version 1.4 is now on the Apple Store. Update has these new features:
    * added range calculation based on kWh per 100 km or miles - on/off is in settings
    * new up / down buttons for efficiency slider to make selection more precise
  10. plg
    plg New Member
    Now on the Apple Store - Free
    Features Include:
    - Range calculation you adjust for your driving habits, conditions and speed
    - Charging sessions details - logged and saved and available for viewing
    - Calculates battery size automatically by using charging session details
    - Map for locating nearby charging stations with details and directions
    * In a charging session you only need to add this information using slider controls:
    1. Starting Charge Percent
    2. Ending Charge Percent
    3. Price per kWh
    4. Time charging (timer included in app)
    * EVrc will calculate the other variables needed.
    New in Version 1.6
    Settings:
    • Added Lock Battery Size in Settings to auto calculate the kWhs added in the Charging Session
    Charging Sessions:
    • Added slider for time of Charge Session
    • Added average speed of charge in kWh
    • Added slider for kWh cost along with calculated total cost
    • Added timer to set when charging starts and ends
    • Added save button to save charging session data including GPS location
    • Added a View Charging History button to show past charging sessions
    Map:
    • Added a Go to Map Button
    • Added a button to search for EC charging stations
    Tapping on marker for selected EV Charging location
    • Added button to show details in Apple Maps
    • Added button to give directions
  11. plg
    plg New Member
    Version 1.7 now available
    This update adds an odometer reading to the charging session data.
    Keep track of all your charging sessions - including time charging, starting percent, ending percent, kWh added, cost, location and average charging speed. Saving this data will allow future updates of EVrc to predict future trips based on past history.
  13. plg
    plg New Member
    Version 1.8
    * Odometer reading is now restored from your last charging session and redisplays after exiting the app.
    * Added new calculations in Charging History that calculate miles from last charge and efficiency since last charge.
    * Charging History can now be edited to correct any data previously entered.
    * Fixed various bugs and graphics on iPhone versions.
    Your comments and suggestions are welcome by contacting: [email protected] or on X at @EVrcRange
  14. plg
    plg New Member
    Ev Range and Battery Calculator
    What's New:
    Charging History -
    Now displays the name and address of the charging station based on your location.
    Added a new data field where the kWh used since last charge can be entered manually.
    Added a new data field for storing a trip description.
    Mark W likes this.
