Climate System Fan Turn Off
Discussion in 'Clarity' started by phevophile, Nov 16, 2018.
  1. phevophile
    phevophile New Member
    Hi all!
    I noticed fan is always on even if I turn off climate system. Is there any way to turn it off? Didnt find anything in search.
  3. ClarityDoc
    ClarityDoc Active Member
    When I use the Climate On/Off button (below the emergency flasher button) my fan turns off, too.
    Sent using Inside EVs mobile app
  4. petteyg359
    petteyg359 Well-Known Member
    What did you do to "turn off climate system"? The button to turn the whole thing on/off is the one in the center of the panel with "[fan icon] on/off" on it
  5. Candice
    Candice Active Member
    When you hit the climate system button, there is no on/off button for the actual climate system. That on/off button is only for the a/c. To turn off the heat, you would need to push the actual on/off button. The climate system button only controls the fan speed and the where the fan blows.
