Brand new owner - Charging faster than 7.2kw?
Discussion in 'Hyundai Kona Electric' started by TheLight75, Jun 6, 2019.
  1. TheLight75
    TheLight75 Active Member
    Hi Everyone,
    I just picked up my Kona EV yesterday and am loving it so far! The specs say it has a 7.2kw on-board charger but last night when I charged it for the first time using a level 2 charger I had purchased, the Kona showed the charge rate as 7.5kw consistently over 4-5 hours. This morning when I disconnected it at 90% to go to work, my range was 280 miles.
    This surprised me since the listed range is 258 miles @ 100%.
    Is this typical?
    Thanks!
    XtsKonaTrooper likes this.
  2. Yeah, that's about right. When I charge to 80% it extrapolates to 509 kms (315 miles) which at 90% would be 283 miles. And with mostly city driving, I have noticed that range used is consistently less than kms driven. We use the ECO mode almost all the time. I think the EPA estimate is very conservative.
    However be aware that hwy driving and climate control (in hot weather) will reduce your range.
  3. The OBC is quite robust , I measured 31.8A @241V - 7663 W (day before yesterday and also checked a 19 Soul which had the exact same rate) keep in mind that real kWh to the pack is about 90% of that due to losses. The rate will also slow down with a cold battery.
    Yes it is nice to see all these positive above spec range listings from the GOM, with additional actual ranges above as well.
  4. XtsKonaTrooper
    Thats good stuff.
    Whats your temps there?
  5. TheLight75, don't rely too much on the GoM to be accurate but the SoC (charge) is. Make a note of the odometer, state of charge and the GoM and the start and end of a few trips and you will get a feel for the numbers, about 32% to 38% per 100 miles, and how close the GoM predicts that range.
  6. XtsKonaTrooper
    Its pretty wild, how much ambient temperature has on range. Mine is topping out 450km now.
    Vanryan likes this.
  7. If it's anything like our last summer don't be surprised to see a lot more than 450 ... 525 km at least.
    Jared Potter and electriceddy like this.
  8. TheLight75
    Today was 70f-75f.
  9. As for the OBC DC charge rate, despite the nameplate 7.2 kW DC, noting the wide range of AC inputs possible your result is dependant on your line voltage and the EVSE being set up for 30 or higher amps. 7.1 to 7.6 kW have been reported as a dash reading and anything in that range is considered the full rate.
  10. The 7663W rate I measured input of the EVSE with an rms clamp on and fluke voltmeter (about 15 M from the supply transformer) . Although rated for a higher input voltage, I don't think charging at a higher voltage (over 245V or possibly 277) would do the OBC much good as it's current limiting might get overheated.
  11. What engineer is going to sign off a product that can’t operate reliably at every corner of its nameplate rating?
  12. I was going to leave that alone, but I had to throw this in:
    Esprit1st, Kitsilano and KiwiME like this.
  13. Here is a video of Nigel (EVPuzzle) about the different ways of estimating your range and the best option seems to be to take the mi/kwh reported by the car and multiply by 64kw. However in the end all measurements seem to end up pretty similar. No matter what you use, always leave a buffer. (Honestly, just like you would in an ICE car)
    It's a pretty long video, the important part is in the last half/third of it.
    electriceddy and TheLight75 like this.
  14. Great video. I rely on the 64K divided by km/kWh as well and find that matches actual range accurately with my driving style. Hope they don't come up with an update here as I also will not get it done without more info.
  15. Nigel's presentation of the data seems overly complicated in my opinion, but I totally understand that's it not easy to get your head around, especially when he's trying to compare two different GoM firmware versions. He definitely loves the GoM and he's trying hard to validate and trust it, and he has a fair chance of that living in a flat region of the UK. I dislike the GoM because it's a moving target and consumers are not privy to the formula, plus our roads are more variable.
    The only readings I really trust are the odometer and the SoC. The latter still needs to be tested for having the linearity we expect with energy used, or, since we don't know that, the proxy of distance driven will have to suffice. The graph (which I've posted before) is a 300 km round trip over several hours to test this. It's a mostly-hilly drive with an average speed of less than 80 km/h.
    The first graph is distance driven (in 100 km blocks) graphed against loss of SoC (because that's what happens.) The first data point at the lower-left is at home and the data point at the upper-right is also at home, without any charging stops. The slight "S"-shape in the data points is due to the hills and higher altitude of the destination, which is at the midpoint. The reason for collecting data at numerous waypoints is to validate the linearity of the SoC, which it has, down to 32% SoC. The slope of the curve (24% SoC per 100 km) is the summary of the round trip. The dithering either side of a straight line is remarkably minor considering the variations in speed and hills up to 760 m.
    The second graph is loss of GoM v.s. distance driven, both in kms, characterising the GoM for that day only. The summary of the trip is that the GoM returns 72% of what it estimated, pretty far off but it wouldn't have had a chance to estimate my range because I didn't do the same drive every day the week before. Again, the dithering is very slight considering the same variations in driving.
    Kitsilano likes this.
