Another Tesla Fatality with Fire
Discussion in 'Tesla' started by David Green, May 14, 2018.
  1. Pushmi-Pullyu
    I have no idea what you're counting. I'm pretty sure there have been more than 5 fatalities involved with Tesla accidents, including all Tesla cars since 2008, so taken at face value your statement is nonsense.
    If you're cherry-picking a handful of the most recent ones, then at least have the decency to say what criteria you're using for that cherry-picking.
  2. Pushmi-Pullyu
    Please tell us you're kidding. If not, then logically there are three possibilities:
    1. You are clinically insane.
    2. You are actually clueless enough about the subject to believe that's true (highly unlikely).
    3. You are just posting FUD -- you know it's not true.
    It amazes me that serial Tesla bashers are trying to gin up controversy over a small number of fires in Tesla cars following accidents so horrible that they resulted in fatalities. Statistics clearly show that Tesla cars are more than twice as safe as gasmobiles regarding the hazard of fire, on the basis of miles traveled.
    Tesla has an exemplary record of overall safety, including fire safety, when compared to gasmobiles. This comparison is a win for Tesla!
    NeilBlanchard likes this.
  3. Pushmi-Pullyu
    Let's count the errors here:
    1. There was one (1) instance of a Tesla car in Norway which short-circuited while Supercharging, resulting in a fire. This was of course not "swept under the rug" as falsely claimed here, but investigated an the results announced:
    From Teslarati: "Tesla Identifies Cause for Model S Fire in Norway"
    2. There was a case of another car fire in a Tesla car parked at a Supercharger station in or near Shanghai, but the car was not actually charging at the time.
    3. There has been more than one fire related to a Tesla car charging at home, so which one David Green is referring to is not clear. But in no case did an investigation show that the fire was caused by anything in the car's electrical system. For example, Tesla investigators found that one fire started at the wall plug where the car was plugged in.
    Again, nothing has been "swept under the rug".
  4. Pushmi-Pullyu
    If there is a car fire you are far safer in a Tesla car than in a gasmobile. When a gasmobile catches fire following an accident, it is likely to burst quickly into flames and the flames are likely to spread quickly.
    Contrariwise, li-ion battery fires are slow to start and initially slow to spread. When a Tesla car detects the battery pack overheating, it gives an alarm and displays a warning to pull over safely and exit the car. In every case (with one possible exception), this has given the occupants plenty of time to escape the car before the fire endangered them.
    There was one very recent case where initial reports claimed that one or more people were trapped in the back of a Tesla car which caught fire after a horrible accident -- a case of a teen driver speeding far past the speed limie and driving recklessly -- where bystanders claim the occupants were still alive and were unable to get out before they were caught in the fire.
    However, as I think we all know, such reports should be viewed with skepticism. Bystander reports are often very unreliable, which is why accident investigators rely on physical evidence far more than eyewitness reports. If this was a case of someone killed in a Tesla car fire, it's the first time it has happened. There are certainly other cases where hardcore Tesla bashers have claimed that people were caught inside a horribly crashed Tesla car and were killed by fire, but in every case accident investigators concluded that the occupants were killed by the crash, not by a fire.
  5. Pushmi-Pullyu
    Nope. If that was the case, it should have shown up in crash tests, which it has not. Nice try at FUD, though. :rolleyes:
    Now, there were two Chevy Volts which were subjected to crash testing and then rolled over using a machine, then left sitting in a lot. Those two Volts did catch fire after a few days. But GM claims to have fixed whatever caused them to catch fire, and it seems likely they did since (so far as I know) there has never been a Volt battery fire following a traffic accident.
  6. Martin Williams
    Martin Williams Active Member
    Agreed it won't happen unless the impact is pretty violent. I would guess sudden deceleration of the pack itself from the front is most likely to cause significant distortion, due to the momentum of the whole pack being concentrated into crushing cells at the front.
  7. Just no. This is not physically possible. All the cells are within modules, all the modules are secured within the pack. Nothing moves.
    David Green likes this.
  8. David Green
    David Green Well-Known Member
    Haha! I h
    I do not think the pack can deform without physical impact. I am curious to see a model 3 pack fire. I think with the gel fill, the fire will propagate much more slowly, but at the same time put off some very nasty toxins.
  9. I'm currently watching a Model 3 battery tear down video, but it's long and they haven't gotten to any gel fill that I've heard rumors about. I'll write up a post on the website when I'm done, but it may only be tomorrow.
  10. bwilson4web
  11. David Green
    If you are watching the one from the old, heavy set guy, no need, he does not tear into the battery, just takes the cover off...
  12. I am indeed watching the EVTV one. I've gotten to the taking off the cover part and they were pointing out what various things are. I still have 30 minutes left to watch, but thanks for the warning. :(
    Do you happen to know of any source that discusses this gel, aside from the discussion with Munro?
  13. David Green
    I do not, I think they are the only one doing a complete teardown, and analyzing the build process and materials. Sandy will be back on Autoline After Hours soon to go over the final report, I am very curious to see the update. I am sure he is going to address the gel... environmental issues, and recycling ability as that will be important to life cycle costs for EV's
    Domenick likes this.
  14. The WeberAuto YouTube channel has done Volt and Bolt battery tear downs that were pretty good. Not sure if they're trying to get a hold of a Model 3. New ones are hard to come by, and crashed ones are commanding a strong price yet.
  15. David Green
    Yes, but Weber does not do a build of process which I am more interested in. Munro will be very scientific about the battery, how its made, and what is in it. We will know the exact Cobalt content, and if Tesla is truly ahead of the others in battery making from a scientific standpoint. How many VOC compounds are used in its manufacturer, and how to recycle. It should be very enlightening.
  16. NeilBlanchard
    NeilBlanchard Active Member
    I have personally witnessed a gasoline ICE car catch on fire while idling in a parking lot.
  17. David Green
    Was it the fuel tank that caught fire? Electrical? Oil? I have seen a few vehicle fires, heavy trucks and motorhomes often start in the brakes. I have seen 2 Ford pickups have the transmission catch fire while towing, one you could see the drips of flaming transmission fluid going out while the vehicle was at a stop light.
  18. NeilBlanchard
    It was on the engine, near the carburetor / throttle body, with the hood open.
    My point is, there are dozens of car fires each and every day, in just the US.
  19. David Green
    I see, so caught fire while being maintained? I have seen that, my 69 Camaro 302 in high school used to backfire through the carburetor sometimes if I had the timing too retarded, but it would not start hot if it was too advanced... It was a delicate operation to get it just right, since I did not have a timing light, it was all by sound of the engine.
    But comparing fire risk of modern Tesla's against the entire fleet of licensed vehicles is misleading as most cars are 10+ years old... Should compare the fire risk of Tesla, to other BEV, and modern ICE cars in competitive segments. That is a real comparison.
  20. NeilBlanchard
    No, it caught fire while idling. Not in an accident.
