One caution. The tires on the front of the car are P235/50HR19 and on the rear are P255/45HR19 (or similar, depending on whether you opt for 19 or 20 inch wheels), so they’re different sizes. You should never swap wheels and tires from a gas XC40 to a Recharge, since the gas cars have the same wheels/tires on both front and rear. Also you can’t swap tires front to back as is common with rotating radials. This from the Volvo regional service rep. Guess it’s because the weight distribution is biased towards the rear. Sent from my iPad using Inside EVs
