Screen going bezerk
Discussion in 'Clarity' started by stanigu, Sep 24, 2018.
  1. stanigu
    stanigu Member
    So I had my first issue with my Clarity tonight.
    Drive started out normally. I decided to listen to Sirius XM. I press the "Source" button. Nothing happens. I thought, ok, PCs get weird sometimes, so maybe it requires a re-boot. So I do the long press on the Audio on/off button. Nothing happens. I press on the Nav button, and it displays the map as usual. But after a while (maybe 2 minutes) screen goes blank. It starts rebooting after about 2 additional minutes. After that, everything appears normal.
    Maybe it's just a glitch. I'll report back if the problem rears its ugly head again...
  3. Clarity_Newbie
    Clarity_Newbie Active Member
    Bummer. Hopefully this is not a trend. I read on this forum sometime back it may cost $3500 to replace after warranty.
    Hope it works out for you.
    Keep us posted.
  4. stanigu
    stanigu Member
    Thanks. So far so good--has not recurred. Maybe one time thing...
    Louis Nisenbaum likes this.
  5. insightman
    Never forget this always applicable Microsoft Word Tip of the Day from decades ago:
    leehinde, stanigu, JJim and 1 other person like this.
  6. KentuckyKen
    @insightman, drop everything and check out @AnthonyW ’s post. He found the evidence to support your theory on regen when battery full!!!!
  8. amy2421
    amy2421 Active Member
    Did you run the Vehicle Preconditioning before this particular drive?
  9. stanigu
    stanigu Member
    No, I did not. (actually I never have, yet).
