New MINI App accepts VIN while at Southampton port, sends code to my car!
Discussion in 'Cooper SE' started by Chicago, May 13, 2021.
  1. Chicago
    Chicago Member
    I have tried to enter my VIN into the new app several times in the past couple days--hoping to catch my MINI while it was 'on' at the factory or while being checked out or loaded.
    It gave an error message every time.
    Now, at the Southampton port for the second day, it accepted my VIN, asked if I was the primary driver, and sent a confirmation code to my MINI!
    Too bad I have no way of remotely retrieving that code.
    MiniSER likes this.
  3. Noice! Kind of cool to know that your MINI is actually "alive" now.
    Chicago likes this.
  4. Chicago
    Chicago Member
    Even better, it populated the VIN to the old app, and the old app tells you it is a 6 digit code consisting of 0-9 and lets you try as many six digit numbers as you want without re-setting. I tried 30 so far on the old app and it keeps asking for more.
    So, do I want ask my MIT grad to create an IOS program capable of generating all 999,999 possible codes in 3 hours?
  5. Puppethead
    Puppethead Well-Known Member
    Careful, it'd be tragic to lock yourself out of your car before you even see it.
    Chicago likes this.
  6. Chicago
    Chicago Member
    Exactly what my daughter said: Bad dad! No.
    She suspects that the app is very forgiving for the initialization, and then gets tougher, requiring the code to be reset after a few failed attempts.
    Lainey likes this.
  8. GetOffYourGas
    Generating the codes is not the issues - you just need a counter (by the way, there are 1,000,000 codes, not 999,999 because 000000 is presumably a valid code). The trick is getting that app to communicate with the mini app and put the value into that field and hit send.
  9. Hutch
    Hutch Active Member
    The app doesn't work for me. Maybe I need a new phone.
  10. Chicago
    Chicago Member
    To enter the VIN for the first time in the IOS app the car has to be ON. I was surprised that it auto-populated the VIN to the old IOS app.
  11. Hutch
    Hutch Active Member
    I can't even get past the MR. or Miss part.
