HV Range Fix is out and ready for dealer install
Discussion in 'Clarity' started by KentuckyKen, Jun 20, 2018.
  1. Ken7
    Ken7 Active Member
    My wife jokingly said to me, “Thanks, I just lost 650 miles of range!”
    CaryLyn and jdonalds like this.
  3. KentuckyKen
    Tell her it originally calculated range based on her slender figure and low weight but overweight people complained of low range. Honda responded by changing it from weight to gallons. Collect hubby points and enjoy.
    AnthonyW and Steven B like this.
  4. sniwallof
    sniwallof Active Member
    Another member of the 357 club! (Yea!) 357 is a very convenient way to see if the software was installed correctly.
  5. jdonalds
    Interesting. I'm scheduled for the update to be installed tomorrow. But my car is showing 357 today!!!
  6. insightman
    The first Over-The-Air update? Just kidding.
  8. Ken7
    Ken7 Active Member
    No no, you can't back into the 357 club, you have to earn it!!! :)
    On another note, we got our highest indicated EV range yet today, 57! I'd think it had something to do with the new HV range update, but we've had 56 a couple of times prior, so I think it was real.
  9. KentuckyKen
    jdonalds wins the Clarity Serendipity Prize.
  10. Jason Kam
    Jason Kam Member
    Just got the fix done in Canada. It isn't official yet but it's in their system.
    Sent from my Pixel 2 XL using Inside EVs mobile app
  11. KentuckyKen
    Let’s see 357 m in km is 574.54
    Does that mean you joined the 574 or 575 club after update?
    (ie what was your HV range right after the update?)
  13. Jason Kam
    Jason Kam Member
    Right now with about a half tank of gas it shows 276km
  14. JimW
    JimW Active Member
    357 still does not seem correct. From my measurements based on actual gas added to tank, my car consistently gets ~42 MPG on highway. 7 * 42 = 294 miles of HV range.
    357 / 7 = 51 I don't think Clarity will average 51 MPG in HV mode even in optimal conditions. EPA rating is 40 MPG highway, so ~42 seems reasonable, 51 does not.
    I also found the calculated MPG showing in trip computer was 11-12% too high. Did they also fix this calculation? The engine management computer should know very precisely how much fuel is going into the engine. In previous cars, I have found the displayed MPG to be very accurate.
    dpuhrmann likes this.
  15. Ken7
    Ken7 Active Member
    I'd agree, Jim, but coming from where we came from (1,000 miles HV range), I can deal with the remaining error. :)
  16. bobcubsfan
    bobcubsfan Active Member
    In airplanes, the fuel is weighed not measured. More accurate. Chefs use scales when cooking for the same reason.
  17. JimW
    JimW Active Member
    But which is worse? A completely bogus reading that you always ignore, or a 21% high inaccurate reading that you might actually use to determine how far you can make it running on gas? My point is the systems in the car already know precisely how much fuel is being used and how many miles the car has traveled. It is not that hard to get the math right, and most cars seem to get this right.
    I consider having 50% battery left as my "reserve tank" if I run out of gas, so HV range display is nice to have, but not as critical as in ICE car.
  18. KentuckyKen
    357 (miles) seems to be the default number that shows up after the HV range fix update is installed. It will adjust to more accurate numbers as you drive in HV and add gas. That’s why someone called it joining the 357 Club for those in the USA.
  19. Jordan
    Jordan Member
    Hi all, how do I get this fix? My clarity still shows crazy high nunbers on HV range and it's very annoying. I'm in the USA.
  20. vicw
    vicw Active Member
    I'm going on the expectation that it will need to have some significant sampling of gas usage that occurs subsequent to the fix, to improve the accuracy of the estimate over time - at least I'm wishing for that to happen.
    Sent from my Pixel 2 XL using Tapatalk
  21. Ken7
    Ken7 Active Member
    Yup. Add to that once you get down to a very low fuel level, you lose total sight of the HV range anyway as it's replaced with the warning, 'Low Fuel'. So extreme accuracy probably doesn't do you much good anyway as your levels get very low.
  22. Ken7
    Ken7 Active Member
    Jordan, just call you dealer and cite him the technical service bulletin. He should be able to download it from Honda and have it installed in your car. I went to my dealer for an oil change and he had no expectation I was going to ask for this fix. As soon as I gave him the bulletin #, he looked it up and entered it on the service sheet.
    KentuckyKen likes this.
  23. loomis2
    loomis2 Well-Known Member
    If you it the "i" button on the steering wheel it takes you back to the ev/hv range screen, or whatever screen you had visible before.
    Ken7 likes this.
