Has software update reduced your Kona Electric range?
Discussion in 'Hyundai Kona Electric' started by Domenick, Aug 5, 2020.
  1. BaylorBob
    BaylorBob Active Member
    That works. Right Click, Highlite and Print. Using a MacBook Air. I forgot about this. I use it all the time but I just didn't think of it. Thanks.
    Domenick likes this.
  3. BaylorBob
    KonaTom just gave me the answer. Right Click, Highlite Text I want to print and click on print. It works. Thanks
  4. You are partly correct. If you use the auto setting, the car will actually anticipate that it will reach the temperature and then reduce. But if you turn auto off, it assumed that your settings will not change.
    So basically, a higher current setting with auto will use less energy than a slightly lower permanent setting (no auto).
    I experienced that exact behavior with the GOM.
  5. BaylorBob
    I finally had a chance to go out and check the charging limit. The DC and the AC were both set where I had them before the update - at 100% but the car was set for Winter Driving Mode which I never set. Either it was done by the dealer or it was done inadvertently by the update process. I have lived in Southern California all my life and we don't get winters. Our winter days might be in the 60's or low 70's. I unchecked the winter mode. Does anyone know what effect checking or unchecking it would have on the EV range, if any?
    navguy12 likes this.
  6. hieronymous
    hieronymous Active Member
    No winter, no effect!
    KiwiME likes this.
  8. Bruce M.
    Bruce M. Well-Known Member
    My GOM reading hasn't changed notably since the update: still hovering in the 285-290 mile range for a full charge. I'm in the middle of a mini-vacation and doing more driving -- and more highway driving -- than usual.
  9. cmwade77
    cmwade77 Active Member
    Umm, where is winter driving mode?
  10. Not all cars actually have it. Only the ones with the heat pump installed like the Canadian version. The US version doesn't have it.
  11. SkookumPete
    SkookumPete Well-Known Member
    BaylorBob and navguy12 like this.
  13. Seems to have increased on ours, best recharge to 100% before was 515 km, this last week I had 525 and then 530 yesterday (329 miles)
  14. BaylorBob
  15. FloridaSun
    FloridaSun Well-Known Member
    My range is fairly low lately due to heavy AC use and several high speed trips.. I'm only getting around 235 miles range @ 80% right now.
  16. That's terrible! Get rid of the EV and get a gas guzzler! ...
    Of course I'm kidding! That's pretty amazing! Still more than the advertised 258!
    navguy12 and Bruce M. like this.
  17. ehatch
    ehatch Active Member
    Given my experience,I would like to see Hyundai's response to InsideEVs. Wonder if they can ask why their dealerships don't appear to be able to print out vehicle scans.Pretty important with EVs since the tech.controls a majority of the Kona electric.
    Just got it done this month with COVID19 re-openings. The BSM campaign installation didn't go well,got multiple errors.Dealership had to call Hyundai.
    Did a 100% charge on AC,got 470km/292 miles.When I first got the Kona electric in spring 2019,I actually saw 509km/316miles.Pre doing the BMS campaign,I did have issues with my charging,and range during COVID19 stay at home periods that are still happening.I lost about 100km/62miles. Error code,my EPCU was replaced,3 components : inverter, LDC DC-DC converter,VCU .
    Asked for DTC for the above,still waiting for them.Asked to have my Li-ion scanned to see if there's degradation,waiting on it also.
  18. For the past 12 hours (possibly more) the light on the grill indicating that the battery saver is running has been on very frequently. More on than off. What the heck is going on? I'm going out soon to try to start it up to see if there's anything weird going on but the Bluelink health status says systems normal. It's not normal.
    **Edit
    Started the car up. Seemed fine. As usual, despite the"battery saver" light being on there was no icon on the dash indicating it. Like others I've never actually seen that message despite it being shown in the owner's manual.
  19. A lot of the range changes pre & post BMS update could be put down to changes in driving patterns or environmental factors. Sixty-two miles, however, does seem pretty significant. Let us know how this all plays out for you
  20. johnparjr
    johnparjr New Member
    Before the recall work 100% would be 299-310 miles on the GOM and now after the service it’s 289 miles at 100%. Not really worried about it though
  21. hieronymous
    470km at 100% after a battery reset is normal, at least for moderate ambient temperatures. When I picked up my car new, and after this BMS update both...
  22. BaylorBob
    The Date of my Last Charge was August 2, 2020, just before I joined this forum (and a few days after my Dealer installed the Battery Update ). That charge was 298 miles. Yesterday, August 27th, was the 1st time I charged my car since then. I plugged it in at 9pm and it charged all night until I unplugged it at 7am today. The mileage increased slightly to 303 miles and it was a 100% charge. Not a great improvement, but some. Because of the Covid-19 Lockdown, I haven't been driving much. All of my driving was done in the ECO Mode. How many more charging cycles do you think it will take to get me back up to 330 or more miles?
