First trip in an ID.4
Discussion in 'ID.4' started by ericy, Mar 22, 2021.
  1. ericy
    ericy Well-Known Member
    This morning I drove into DC, and I can share some notes.
    Starting point this morning was 83% charge on the battery, GOM showed 298 miles. Temperature was about 47 degrees, car was in the garage overnight. I didn't get around to preconditioning. I suspect if it were warmer that efficiency would improve a bit.
    The GOM implies that a 100% charge would give you 350 miles. That seems ... optimistic. That being said, I would want to precondition the car to warm the battery if I wanted to maximize range.
    I had the heat off, but the panoramic roof window let in a lot of light, and it warmed up nicely. Almost too warm, really. I ended up closing the shade later on.
    The travel assist works quite well, but it disengage if you tap the brakes. The steering wheel has a capacitive sensor that knows when your hands are on the wheel - this works well, and I didn't get any bogus warnings about needing to hold the wheel. Just one or two fingers lightly resting on the wheel is enough to keep it happy.
    The car has both a built-in navi as well as Android Auto. General concensus is that AA works better. Voice commands to the builtin navi were frustrating. There is an optional add-on to CarNet to add natural language handling - I haven't tried this yet.
    Adaptive cruise control works well. There is a view on the dash that shows you the cars in adjacent lanes as well as cars ahead of you. It alerts you to cars in the blind spot - lights come on in the side view mirror. I believe that if you attempt a lane change while a car is in your blind spot thet you get a warning.
    At the end of the trip, here is what I had. So I used 50% of the battery, and went 147 miles. At the end, the GOM had 110 miles left.
    Incidentally, the same trip in the Kona also took 50% of the (smaller) battery. 20210322_123416.jpeg 20210322_123401.jpeg 20210322_123348.jpeg
  3. Thanks for the pictures...pretty good consumption (3.6 m/kWh) @ those temperatures and comparable to the smaller Kona EV.
    I see quite a bit of reflection on the screen, does the panoramic roof add much of that or is it relatively easy to see?
    You should break 300 miles with ease once warmer conditions occur.;)
    mho likes this.
  4. ericy
    The window shade was closed when I took these, so it is more to do with where I was parked, I guess.
    I didn't notice the glare at the time, so I guess it is easy enough to see.
  5. Nice review.
    Thanks.
  6. stewf
    stewf New Member
    Thanks for your reports, @ericy! I have an ID.4 on order, and as a longtime Honda Fit owner my main hesitation is size. I’m so accustomed to smaller hatchbacks (my previous car was a 1990 Honda Civic Wagon). I saw you used to drive a Kona. How is your experience transitioning to this larger SUV? (Obviously, I am really bummed we can’t get an ID.3 in the US.)
  8. Tony S
    Tony S Active Member
    Thanks for the review; encouraging data, looking forward to driving impressions (acceleration, control, suspension, cabin noise, ...). How is the low speed pedestrian noise?
  9. papab
    papab Member
    What's GOM?
  10. GOM "Guess O Meter" It is the part of the instrument display that shows your estimated remaining distance (km or miles) based on the current state of battery charge (SoC)
  11. navguy12
    navguy12 Well-Known Member
    "Guess-O-Meter" :)
  13. M Chung
    M Chung New Member
    I thought the VW ID (only option available now) can only go 250 miles
  14. ericy
    Thats the EPA range. Actual range will depend on a variety of factors (speed, temperature, whether you have the heat on, etc, etc).
    Some cars underperform the EPA range. Some cars overperform (never seems to happen with ICE, but some EVs do).
  15. ericy
    In some ways I would have preferred an ID3 myself, but that wasn't an option. One of my complaints with the Kona was lack of cargo space in back, and that the back seats were uncomfortable for adults. Other than that, I was generally satisfied with the Kona, at least until the BMS fail. So I was looking for something somewhat a bit bigger to begin with. That being said the thing is a bit bigger than I envisioned when I first put in the reservation. When I have it in the garage next to my wife's Golf, then it stands out a bit more - partly because it is taller, perhaps a bit wider.
    And as big as the thing is, I saw someone on Twitter complaining that it wasn't big enough (they wanted 3rd row of seats). That's the other thing about this that surprises me a bit - people have this list of things that the car must have or it is a deal breaker, and I just don't quite get it. If you want an EV, there just aren't that many things to choose from - I guess that was my deal breaker.
    The place I notice the size is in narrower lanes (near construction zones, for example). Places where other people crowd over into your lane because they don't like to be up against the temporary concrete barriers. You really need to turn off some of the assist features in these situations - otherwise the car is fighting to center you in the lane when that's not quite where you want to be.
    I have never been one to be fixated on 0-60 times. But for me, the acceleration is fine, and I have the thing in ECO mode. Some people have test driven Tesla, and they are then disappointed that the ID.4 doesn't perform the same way. I have heard comments that if you put the thing in a sport mode, that performance is better, and for people who fixate on this sort of thing, it seems to somewhat satisfy them.
    Handling and control for me are fine - if you have driven other VW (or other European cars), you will likely be happy with the thing.
    The pedestrian noise doesn't bug me - yeah I hear it, but it just isn't an issue. The noise in the Kona didn't bug me either, but I know that several people disconnected the thing because they didn't like the sound.
    stewf and navguy12 like this.
  16. Tony S
    Good to hear that. Yes, I’m familiar with European cars since my first one in 1966 (a Beatle!); since then, I had many of Dr. Porsche’s creations . I’m replacing my ‘14 BMW X1 sDrive RWD with the ID.4 AWD and looking forward to sampling the transportation of the future.
  17. Raja Nathan
    Raja Nathan New Member
    Hello, I test drove ID4 1st and ID4 Pro. I cant find how to make the 'Hill start assist' and the 'Park Hold' working.
    Does ID4 has 'Hill start assist' and the 'Park Hold' ?
    Thank you
