evse recommendations?
Discussion in 'Cooper SE' started by KeninFL, Jun 13, 2020.
  1. ColdCase
    ColdCase Active Member
    Yeah the smart chargers can limit charging to a schedule you set via their APP or web interface. But the Mini App is more convenient. And if you happen to have a friend over that needs a top off, there is nothing to do besides plug it in.
  3. Puppethead
    Puppethead Well-Known Member
    I have a classic (dumb) Grizzl-E and use the MINI app to control charging during off-peak hours; it works really well. You set the charge window start and stop times, and then specify what time you want the SE charging to finish. In my particular case I have the charge window to be 21:00-08:59 and have my charging set to be done at 03:30 so it's definitely ready to go when I leave in the morning. The SE does a really good job of back-figuring the start time to charge, and it's always fully charged on or before the set time.
  4. J.Dubs
    J.Dubs Member
    Do you ever wish the Grizzl had data? an app? or even a screen?
    I debating between that one and the juice box
    https://www.amazon.com/gp/product/B07ZL41687/ref=ox_sc_act_title_1?smid=A3RM0KG48LQ5IK&psc=1
  5. Whosehouse
    Whosehouse New Member
  6. Puppethead
    While waiting for my SE I gave a lot of thought about a smart EVSE. I ultimately decided the functionality (and added complexity) didn't justify the higher cost, and the Grizzl-E is a perfect "it just works" EVSE that also has cold-weather features that were important to me. I may get a smart Grizzl-E at some point when the features are there, because I like the idea of collecting charging data. Although my EVSE is on its own meter so I know exactly how much energy I use per month.
  8. ColdCase
    When I was shopping awhile ago, the Grizzl-E was out of stock, but the Smart Grizzle-E was available for like $40 more. The smart web portal provides quite a bit of info, dunno how much more an app will bring beside production values.
  9. J.Dubs
    J.Dubs Member
    I didn't know they had a smart one I'll buy that.
    https://grizzl-e.com/product/usa/smart/grizzl-e-smart/
  10. endquote
    endquote Active Member
    Thanks to all who have contributed this thread, as I'm trying to figure out my home charging situation while I wait for my SE to come into existence.
    One thing not mentioned (or perhaps I missed) is the estimated cost of the electrician to do the installation. My ideal charging location is indoors, very near my meter, and only a couple of feet away from the car. The building is new construction so hopefully no weird wiring surprises. What should I expect to pay an electrician? I'm in San Francisco.
    I received a quote from one electrician for $3500, excluding the charger itself. I'm willing to pay for good work that won't cause my house to explode, but that seems like... a lot?
  11. J.Dubs
    J.Dubs Member
    That’s insane. I paid $100 plus materials. Installed in garage about 1’ from breaker box
    endquote likes this.
  13. GvilleGuy
    GvilleGuy Well-Known Member
    That is insanely high, even for a more expensive cost of living area like San Francisco. My opinion is $650 to $1,000 without EVSE. I would get multiple quotes. Also, in case you don’t know, you can get back 30% of the electrician and EVSE cost on fed taxes next year, capped at $1,000. IRS form 8911.
    J.Dubs and endquote like this.
  14. quietlyspinach
    quietlyspinach Active Member
    I started a separate thread for that if you want to add your quote to that. Your quote is the highest by far.
    https://www.insideevsforum.com/community/index.php?threads/electrician-cost-to-add-level-2-240v-outlet.11180/
  15. Whosehouse
    What's the web portal? The acharger.ca thing?
  16. ColdCase
    Grizzl-E set up free access at acharger.ca which is a OCPP server where you can add your charging station and gather info. The smart is also compatible with third party OCPP 1.6 compliant central systems or applications.
  17. J.Dubs
    J.Dubs Member
    I purchased a Grizzle E charger and had it installed today. When I connect it to the car I only get the flashing blue lights and it never starts charging. Any ideas? IMG_0666.jpg
  18. ColdCase
    I think earlier in the thread someone mentioned a firmware update. Is your SE fully charged at the moment? Usually that means the vehicle is detected but is not asking for power. If its alternating blue and light blue it means its ready, hard to tell them apart sometime.
  19. J.Dubs
    J.Dubs Member
    I'm at 53% I also tried flipping the dip switches to 32amps
  20. ColdCase
    Look for whosehouse posts earlier. Sounds like something similar and he needed a firmware update.
  21. Whosehouse
    This is exactly what I had happen (but with the Smart version). I did every possible step to try and fix it. Ultimately, they did a server side update (I think) which made it work. If you want the tech guy's email, DM me (or this website's version of that).
    J.Dubs likes this.
  22. Carsten Haase
    At least on the "dumb" Grizzl-e, there is no light blue:
    When my car is plugged and not requesting power (either because it's charged or because of the set schedule) the light is solid green
  23. MichaelC
    MichaelC Well-Known Member
    What does your MINI's charging status show?
