Driving Clarity PHEV without gasoline
Discussion in 'Clarity' started by Neil, Sep 24, 2018.
  1. Neil
    Neil New Member
    Has anyone tried driving the plug in hybrid without any gasoline but the battery charged? I'm wondering if letting the gas tank run until completely empty is ok. Presumably the car would switch to EV-ony mode regardless of setting? I've heard driving with low gas is bad for regular cars' fuel pumps, wondering if same would apply here.
  3. PHEV Newbie
    PHEV Newbie Well-Known Member
    I would caution against trying that. There are many instances when the gas engine will try to turn on, no matter what mode you're in. Besides, that's an ICE, that needs to run occasionally to stay properly lubricated. The oil used is super thin so it won't keep a protective layer on metal surfaces for very long.
    Neil likes this.
  4. Neil
    Neil New Member
    Thanks. I found the other threads and it looks like Honda doesn't explicitly say don't do this but I think you're right probably not a good idea if you can avoid it
    sabasc and (deleted member) like this.
