Wheel Lug Nut Torque
Discussion in 'Clarity' started by Richard Hwang, Jan 19, 2019.
  1. Richard Hwang
    Richard Hwang New Member
    My research indicates 80 ft-lb. Is this correct?
  3. Richard Hwang
  4. Robert_Alabama
    Yes, 80 ft-lbs is correct torque for lug nuts.
  5. KentuckyKen
    Yes, 80 ft-lbs of torque and a 19 mm lugnut are pretty much standard for almost all Honda wheels. I appreciate the confirmation from the College Hills Honda document.
  6. bpratt
    bpratt Active Member
    I was always taught to tighten them down until they strip and then back off 1/4 turn.
    David Towle and insightman like this.
  8. KentuckyKen
    I prefer to use German Torque:
    “guduntite”.
    But I back up the same way: just ease back until you hit something and then pull forward a few inches.
  9. David Towle
    David Towle Well-Known Member
    I think everyone designs wheel lugs today for at least 200 ft lbs since that's the sort of torque that tire shops use. But 80 is 100% secure and makes it much easier to get them off on the side of the road if you need to.
