Unknown part in trunk during delivery
Discussion in 'Clarity' started by Yukon903, Jul 29, 2018.
  1. Yukon903
    Yukon903 New Member
    The following was in the trunk of the 2018 Clarity PHEV and neither the sales guy nor the tech he spoke to had any idea where it goes/came from. Any help would be greatly appreciated.
    (Thinking that it could be an access cover or something in the undercarriage, but unable to see anywhere it may fit.)
  3. JCEV
    JCEV Active Member
    Could it be the front license plate bracket ?
    neal adkins likes this.
  4. Streakr6
    Streakr6 New Member
    I have a Honda Element that has a very similar part under the steering wheel, I would check my Clarity, but my back says NO...
  5. KentuckyKen
    It’s not the license plate frame; I’ve got that part. I can’t find it in the trunk, under the hood, or in the cabin. The two turn latches make me think it’s not for the unprotected underside of the car since road debis could unlatch it. And if it came from a protected area, there’s no reason for the service or prep guy to open it up to get to it. I’m stumped.
    Does it look new or used. If it looks used, it’s probably not from your new Clarity. Take it to the parts counter and see if they can look up the numbers on it and tell you what it is and what it goes to.
  6. lordsutch
    lordsutch Member
    Google says "PP-GF30" has something to do with the radiator fan assembly on Hondas, which I guess would explain the gasket.
  8. Yukon903
    Yukon903 New Member
    Part looks to be new. The gasket on the underside and the tabs with the turning latches have me thinking it could be something under the rear bench, like a access cover. Will try and make it by the parts Dept, when I schedule for the tinting to be done along with some other “we owe” items.
  9. Yukon903
    Yukon903 New Member
    Finally got an answer... it does NOT belong in the Clarity PHEV. It actually goes to a Ridgeline and is an access cover. About a $300+ part that another customer was missing.
    Pegsie and Remarksman like this.
  10. weave
    weave Active Member
    How the hell does that happen?!
    $300 for a plastic door. Wow....
    Pushmi-Pullyu likes this.
  11. KentuckyKen
    Dealerships never fail to amaze and disappoint me at the same time.
    Maybe that Ridgeline was delivered with a bed full of all our missing underbody plugs!
    FlaDave, David A and Viking79 like this.
  13. Pushmi-Pullyu
    I second that "Wow"! This is a mass produced part, isn't it? Honda must make them (or more likely, buy them from a supplier) by the tens of thousands? How is that not price gouging?
