Preferred Setting for Trip Meter Resets?
Discussion in 'Clarity' started by Demian Johnston, May 3, 2018.
    It seems that I'm not alone in wishing for more information about our driving performance. I was thinking of experimenting with these Trip Meter reset settings.
    How do you all use these settings?
  3. Emanuel Green
    Emanuel Green Member
    Ever since I've gotten mine, the trip meter fuel efficiency has been pegged at 199.9mpg. I really wish there were some way to see mpge or miles/kWh or something :-(
  4. jdonalds
    I use the Reset To Zero after recharge on the B trip meter.
    bfd likes this.
  5. iluvscuba
    iluvscuba Active Member
    What is 'IGN OFF' mean?
    Edit: I guess Ignition Off
  6. Hi.Ho.Silver
    Hi.Ho.Silver Active Member
    I use the automatic “Reset To Zero after recharge” on Trip A and have left Trip B alone thus far.
  8. bfd
    bfd Active Member
    I didn't even know that was a feature! Thanks! I guess default must be manual reset.
  9. Jaketesla
    Jaketesla Member
    Does the display get capped at 200 mpg? You could change your display to metric and then convert the number. In metric it shows the number of litres per 100km so the better your mileage the lower the number therefore it doesn't get capped. Right now I am getting 0.7L/100km which is equivalent to 336 MPG.
  10. Jaketesla
    Jaketesla Member
    I have it set to reset Trip A after refueling. That way I can see how far I've driven on each tank of gas.
  11. Emanuel Green
    Huh, that's interesting! I will try it and see what I get :)
  13. Emanuel Green
    Mine says 0.4L/100km. So something like 588mpg? Cool [​IMG]
    Jaketesla likes this.
