OBD2 port location
Discussion in 'Hyundai Kona Electric' started by electriceddy, Mar 18, 2019.
  1. So the port( Canadian version) is located under the dash below the fuse panel (above the hood release) unlike the reports from UK(one person is producing a fuse cover with a hole to accommodate.
    This make it SUPER easy to run an OBD extension cable c/w 90 under the dash supported by existing wire harnesses and exit under the steering wheel (attach the reader w/velcro).
    Still have to download Torque pro and pertinent files, (later)
    Link to cable
    https://www.amazon.ca/dp/B00J2N0VG4/ref=asc_df_B00J2N0VG43251291?smid=A1NX1V525JVRQF&linkCode=df0&creative=395393&creativeASIN=B00J2N0VG4&tag=shopbotca-20ext
    Link to reader has been discontinued (v1.5)
    https://www.ebay.ca/itm/Mini-OBD2-ELM327-V2-1-Bluetooth-Car-Scanner-Android-Torque-Auto-Scan-Tool-OBD-II-/153262963680?oid=111329509215
    I think v2 has auto shutoff mine has a power switch, safer to have an in line power switch on the cable itself if using a reader without one.
  3. robxb
    robxb Active Member
    How did the cheapy work out for you? Does it work with ABRP?
  4. Cable routing works, bricked my phone, work in progress?:rolleyes:
