Navigation Map Update available
Discussion in 'Clarity' started by Hi.Ho.Silver, May 11, 2018.
  1. Hi.Ho.Silver
    Hi.Ho.Silver Member
    I got a notification on my PC this morning of a map update for the Touring model. I successfully downloaded and installed it this afternoon. Since I don’t have the time or desire to drive the entire country I will rely on others to assess the changes.
    GTO 409, Kestrel and Johnhaydev like this.
  2. bobcubsfan
    bobcubsfan Active Member
    On Mac. Did not see update notification.
  3. STEye
    STEye New Member
    How do you get notifications about map updates? How do you update the maps?
  4. Terry Neudorf
    Terry Neudorf New Member
  5. bobcubsfan
    Instructions refer to a .exe file. I have a Mac, so I cannot do it.
  6. ManKo
    ManKo Member
    Is this the same update some of us did earlier this year around January/February?
    Bobcubsfan, there is a Mac version of Garmin Express available in the downloads.
  7. Hi.Ho.Silver
    Hi.Ho.Silver Member
    I believe that this is a new update. I did an update in February when I took delivery and then got the notification on 5/11 for an update which I performed. I don’t think it would have downloaded the data from Garmin if it was the same version that was already on Clarity.
  8. dstrauss
    dstrauss Active Member
    How are you guys getting notifications - I registered at Honda but nada.
  9. dstrauss
    Just went to the website above - YOU HAVE GOT TO BE KIDDING - start car and Nav app - insert USB and wait until it says process then go to computer - download update (don't turn off the car) go back to car with USB and continue install - anywhere from 1-4 HOURS - with car running all the time. That's ridiculous! So much for upgrading Garmin...
    GTO 409 likes this.
  10. KentuckyKen
    KentuckyKen Active Member
    Pretty sure I turned off car after first step. Took about 2 hr to down load on my computer/internet connection. Went back to car and that’s when you have to keep car on until complete.
  11. Tailwind
    Tailwind Member
    This was my experience:
    5 minutes in the car for the first step, about 45 minutes to download the update on the computer, and about 15 minutes to do the update in the car.
  12. ManKo
    ManKo Member
    I did my last one while driving. Make sure your trip will be at least 15 minutes. Other functions continue working during the update. You can even have the upgrade happening in the background and use the radio etc.
  13. bobcubsfan
    Easier to use CarPlay with my iPhone using the Maps app.
    GTO 409 and dstrauss like this.
  14. Elm
    Elm New Member
    I just tried to update my map and I can't get my Clarity to recognize a freshly formatted USB drive. I don't know what to do next. I've reformatted the drive multiple times on both a Mac and a PC to FAT32. The computers report the drive is working correctly. The car is even in range of my wifi - don't know if that is even an alternative. I'm not sure what the next trouble shooting step is.
  15. rodeknyt
    rodeknyt New Member
    I did an update on our 2016 Pilot and then on our new Clarity. Even though I reformatted the flash drive between the updates, the Clarity wouldn't use the one I had used on the Pilot. The car must be looking at the low-level device name and/or something that the car writes low-level to the drive and won't use one that is "attached" to another Honda. I scrounged up a different flash drive and everything worked as it should.
    If you previously used that flash drive to update a different Honda, maybe that's what happened. If not, I got nothin'.
  16. Elm
    Elm New Member
    Thanks. I've never used the drive on any car, just a Mac. I reformatted the drive on a PC then immediately walked to the car and plugged it in. Turned on the car and car asked me to insert a USB storage device. Dunno what else I can do.
  17. rodeknyt
    rodeknyt New Member
    Try a different drive if you have one.
    Elm likes this.
  18. Sandroad
    Sandroad New Member
    Although I've not tried the Clarity update yet, I went through the same thing on my Ford Fusion when attempting to update Sync3. The issue is likely that your usb drive formatting is screwed up. It often does not work to move a usb drive from one platform to another with vehicle software. Start with a brand new usb drive with native (original) PC formatting. Use that for all the Clarity downloads, backloads, reloads, frontloads, uploads, and blowuploads. I'll bet that will work.
    To add a humorous caution, note that these software minefields are being brought to you by the same companies that are making self-driving cars :eek:
    KentuckyKen likes this.
  19. Hi.Ho.Silver
    Hi.Ho.Silver Member
    What is the capacity of the thumb drive that you are using? I had trouble using a high capacity (64gb) and used an 8gb successfully.
  20. Elm
    Elm New Member
    I've been using a 16GB drive. I'm currently erasing it - writing zero's three times - tomorrow, I'll reformat and try again. If that doesn't work I'll try Sandroad's suggestion and buy a new one.
    Johnhaydev likes this.
