I came home today and plugged in my Clarity per usual, but right after I attached the already plugged in level 1 charger, the green light came on along with a loud beep (maybe 2 seconds). Unsure if it came from car or charger. Anyone else experience? Could replicated by unplugging and plugging in again. Car seems to be charging...
The car will beep when you charge after you use the fob to open the charger door. I did the same thing yesterday and noticed the beep. You won't get the beep if you open the charger door with the button inside the car.
