Jacking instructions for tire rotation/changing?
Discussion in 'Hyundai Kona Electric' started by R P, Nov 7, 2019.
  1. Was looking in the manual and did not see any instructions on where/how to place the jack. Every other car I've owned was always very explicit about this. I want to rotate my tires, but want to be sure I don't damage anything by using the wrong jack or jack point.
    I am being extra cautious because with my son's Tesla, they have very specific instructions because of the battery underneath, and this procedure can only be done by Tesla authorized shops. It requires some kind of adapter for the jack. If there are any marks on the battery cover, the warranty is voided.
    navguy12 likes this.
  3. [​IMG]
    From speakev forum
    BC-Doc and electriceddy like this.
  4. Yeah, I see the pinch welds there, and slots looking very similar to my other cars. But the Kona EV manual doesn't mention these, and there was no scissor jack that came with the car. And I know an EV is much heavier than a similar ICE model version.
    I am probably being needlessly over cautious here, but just want to make sure I don't screw anything up.
  5. Looks like the lift points are on the flat frame portion behind the pinch welds. Again this was from the speakev forum, please credit the original poster rbilodeau
    for the pictures
  6. Last edited: Nov 7, 2019
  8. From that pic looks like they are lifting right on the pinch welds (red part), which is what I would expect, between the two notches.
    Bugblndr likes this.
  9. hobbit
    hobbit Well-Known Member
    There's enough frame "meat" next to the pinch welds that a jack can center to
    one side of the weld or the other, esp. if it doesn't have the suitable slotted
    fitting to straddle the weld but still push up on either side of it and not on
    the edge of the weld itself.
    I have fit a generic scissor jack and a backup jackstand in next to each
    other with safe purchase on both, without endangering the battery
    framework.
    _H*
  10. navguy12 and electriceddy like this.
  11. Hockey pucks work as well, used them on my Leafs
    navguy12 and ericy like this.
  13. Yeah, had an old hockey puck and could have carved it up. But this one is a little smaller and fits into the cup of my floor jack, so should be a little more secure. Anyway, it was pretty cheap, so that I would give it try.
  14. electriceddy likes this.
  15. Nice solid jack:) Did you have to jack all 4 points or did jacking one side lift the car enough to change both tires?
  16. While looking up where to place the jack, I found some images showing how to jack the entire front end, or back end. However, as I'm inexperienced with this, and with an electric car, I chose the safe option and changed one tire at a time. It took about an hour, all said and done. There was a bit of an investment initially, with the jack, a good torque wrench, breaker bar, and some other small items. But with 3 cars in our household now, it was a small investment compared to paying to have tires switched over twice a year. Plus, I can do it when I choose rather than having to try and get the car booked in at the same time as everyone else.
    navguy12 and eastpole like this.
  17. I used a small trolley (floor) jack to lift each corner in turn, for a inspection. The car lifts easily at the indicated jacking points, not nearly as heavy as I thought it would be.
    Everything is clean (12,000 km) and brakes are barely touched even though I normally use only the pedal. Glad to see that the rim hub is correctly fitted with vents to both the hub center and the casting pockets so water gets drained. The rear brake was just as clean.
    8C1C4627-F780-4C25-895F-FA639FBB42D9_1_105_c.jpeg C85D13DA-56C7-46FA-9CFE-03822157D6B3_1_105_c.jpeg
  18. Please help me understand what the correct jacking scheme is... Is the actual pinch-weld edge used for lifting, between the notches, and the hockey puck with grove is just there to give better support?
    ...or is the hockey puck slot/groove supposed to be deep enough that actual support/lifting takes place not on the pinch-weld edge but rather adjoining the edge on the frame?
    Sandor Belenfant and navguy12 like this.
  19. The edge of the flange in between the two notches is what is intended to take the load, or "pinch weld" as it seems to be colloquially known. The pad on a trolley jack (floor jack, forgot who uses which term) will grasp that safely (if centered) but the puck seems to be someone's idea of how to protect the flange from minor deformation. I saw these first used on BMWs because if I recall there are no DIY jacking points. Because we're a number 8 wire country in NZ we can't find such fluffy accessories locally so I just use a tough material in between to minimise scratches, but thin enough so that the car's flange locates inside the jack's notches. Thick leather would be ideal. The puck is not intended to take the load to the sheet metal as far as I'm aware. Have a look at the Hyundai image above. The lift shown has flat pads.
  20. The flat pad is what's confusing me, I think. My Santa Fe had a similar pinched weld but not nearly as high so I made some pads out of 2x4 to put the weight on the frame instead of the edge itself. Maybe I didn't need to.
    So to recap... it is perfectly ok to jack on the pinch-weld edge as long as it's between the notches?
  21. mikeselectricstuff
  22. Lifting the Kona to remove a wheel is a piece of cake. The pad I used is a piece of reinforced silicone rubber but is not needed. Most important is that the car's flange sits inside the jack's teeth.
    5E233FA0-BAB8-404F-842B-92AD2A6DB9A6_1_105_c.jpeg A08C1CB0-EB37-4573-B444-9235E7105BC3_1_105_c.jpeg
    navguy12 and FloridaSun like this.
