Is it ok to charge at low temperature? (0c or lower)
Discussion in 'Clarity' started by bigbug, Oct 26, 2018.
  1. bigbug
    bigbug Member
    As winter is coming, there are more chances that I need to charge in public station below 0 degree (C). But I remember reading somewhere that battery degrades faster when charge at low temperature. Can anyone comment on this?
  2. marshall
    marshall Active Member
  3. KentuckyKen
    “Trust the Force, Luke”...err..., I mean the Battery Management System.
  4. AnthonyW
    AnthonyW Well-Known Member
    The Canadians have dedicated battery warmers. Here in the US we have a thermistor system. With a thermistor, internal resistance is higher at lower temperatures. Thus, initial charge energy does not go into the battery but is lost as heat-heat that warms the battery. As the thermistor heats up resistance decreases and charge starts to go into the battery. I don’t believe that the thermistor system is as robust as the dedicated battery warmer or else the Canadians wouldn’t have a different system. That said the operators manual says that at -22F the car will not start. One could assume that above that temp it is okay to charge.
